[GRASS-user] v.out.ogr warning when exporting to shapefile
Mira Kattwinkel
kattwinkel-mira at uni-landau.de
Mon Feb 18 02:21:13 PST 2019
Dear list,
I need to export some vector data to ESRI shapefiles. I use v.out.ogr
and get several times warnings like:
"Warning 1: Value 152469999.479999989 of field areaArabA of feature 6
not successfully written. Possibly due to too larger number with respect
to field width"
However, this field contains values with 2 decimal places and
v.db.select correctly returns 152469999.48. I create the column using
v.db.addcolumn and column type double precision, and fill it using
db.execute and an sql statement including ROUND.
I suppose, this is a shapefile issue, but is there any workaround?
Thanks a lot,
Mira
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Phone: + 49 6341 280-31553
Office: Building I, Room 2.02
