[GRASS-user] r.width.funct in correct version
Juan Lopez
cubarro at gmail.com
Thu Feb 21 04:31:23 PST 2019
Thank you Margherita Di Leo, Veronica, Helmut and Nikos.
Trying to show some of my searches, I found an explanation of that
IndexError in python discussion
<https://stackoverflow.com/questions/32978575/how-to-fix-indexerror-invalid-index-to-scalar-variable/32979196>
I seems to be a python specific problem. But I am not sure nor able to use
it...
This is the link
It is curious that previous grass versions works perfect with the same
r.width.funct
Regards
On Thu, Feb 21, 2019 at 8:21 AM Margherita Di Leo <diregola at gmail.com>
wrote:
> Hi,
> On Thu, Feb 21, 2019 at 1:04 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> I get the same error that Juan gets, both with his commands and with
>> those in the example in the manual page (and both in grass76 and trunk).
>> [omitting the rest for brevity]
>> r.width.funct map=dist2out image=/tmp/my_basin
>> 100%
>> Tot. cells 88407.0
>> Tot. area 8840700.0
>> Max distance 7714.591101
>> Traceback (most recent call last):
>> File "/home/veroandreo/.grass7/addons/scripts/r.width.funct", line 135,
>> in <module>
>> sys.exit(main())
>> File "/home/veroandreo/.grass7/addons/scripts/r.width.funct", line 84,
>> in main
>> prc[0,0] , prc[0,1] = findint(kl,0.05) , 0.05
>> File "/home/veroandreo/.grass7/addons/scripts/r.width.funct", line 128,
>> in findint
>> z1, z2, f1, f2 = kl[int(Xf[0])][0], kl[int(Xf[0]-1)][0],
>> kl[int(Xf[0])][1], kl[int(Xf[0]-1)][1]
>> IndexError: invalid index to scalar variable.
>> No idea...
>> Maybe Madi can help us out here :)
> I wish :-) The fact is that I don't know what caused the error because it
> was working fine previously. As soon as I have time I will look into it,
> but if someone else has idea of what's causing the error, it's more than
> welcome.
> Margherita Di Leo
Prof. Juan Ygnacio López Hernández Ing. MSc. PhD.
Universidad de Los Andes <http://www.ula.ve/>
Escuela de Ingeniería Forestal
Mérida, Venezuela.
Tel. ++58 426 3185690
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190221/28d8743d/attachment-0001.html>
