[GRASS-user] postgresql geometry parameter not respected in v.in.ogr -r
Markus Metz markus.metz.giswork at gmail.com
Tue Feb 26 12:12:32 PST 2019
On Tue, Feb 26, 2019 at 5:05 PM patrick_s <patrick_GIS at gmx.net> wrote:
> Dear list
> The syntax of v.in.ogr ignores the "geometry" Parameter, when using the
> "spatial" Parameter or "-r". A workaround is the use of v.clip and
g.rename.
> I am a longterm user, but unregular user and have no userid to start a
> ticket. Hope this helps for future development nontheless.
Of course it helps! Which GRASS version are you using? v.in.ogr has changed
quite a bit recently, therefore we recommend to use GRASS 7.6.
Best,
Markus M
> Best,
> Patrick
> #using flag "-r" and "spatial" finds "2990 vertices registered"
> v.in.ogr spatial="2653156, 1249949, 2675000, 1267232"
> input="PG:dbname=psql_local" layer=${DBSCHEMA}.${DATASET}
> out=gr_${DATASET}_${REFYEAR} type=point geometry="geom_2" -o --o
> v.in.ogr -r input="PG:dbname=psql_local" layer=${DBSCHEMA}.${DATASET}
> out=gr_${DATASET}_${REFYEAR} type=point geometry="geom_2" -o --o #2990
> vertices registered
> #clipping with same region after loading reduces to "1079 primitives
> registered"
> v.clip in=gr_${DATASET}_${REFYEAR} out=gr_${DATASET}clip_${REFYEAR} -r
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190226/117eedb6/attachment.html>
