[GRASS-user] postgresql geometry parameter not respected in v.in.ogr -r
Markus Metz markus.metz.giswork at gmail.com
Tue Feb 26 12:39:53 PST 2019
On Tue, Feb 26, 2019 at 9:17 PM patrick_s <patrick_GIS at gmx.net> wrote:
> Thanks Markus
> My GRASS-version is 7.4 from standard Ubuntu 18.04.2 LTS repository;
This should work as expected. AFAICT, the spatial option and the -r flag
are properly passed to OGR.
Are there any warnings or errors in the output messages of v.in.ogr?
In order to help testing, you could use OGR directly to extract a spatial
subset:
ogr2ogr -spat 2653156, 1249949, 2675000, 1267232 -geomfield geom_2 -f GPKG
test.gpkg "PG:dbname=psql_local" layer ${DBSCHEMA}.${DATASET}
and test if you get the expected result.
The arguments for ogr2ogr are derived from your information and untested.
Markus M
> Regards,
> Patrick
> On 26/02/2019 21.12, Markus Metz wrote:
> On Tue, Feb 26, 2019 at 5:05 PM patrick_s <patrick_GIS at gmx.net> wrote:
> > Dear list
> > The syntax of v.in.ogr ignores the "geometry" Parameter, when using the
> > "spatial" Parameter or "-r". A workaround is the use of v.clip and
g.rename.
> > I am a longterm user, but unregular user and have no userid to start a
> > ticket. Hope this helps for future development nontheless.
> Of course it helps! Which GRASS version are you using? v.in.ogr has
changed quite a bit recently, therefore we recommend to use GRASS 7.6.
> Best,
> Markus M
> > Best,
> > Patrick
> > #using flag "-r" and "spatial" finds "2990 vertices registered"
> > v.in.ogr spatial="2653156, 1249949, 2675000, 1267232"
> > input="PG:dbname=psql_local" layer=${DBSCHEMA}.${DATASET}
> > out=gr_${DATASET}_${REFYEAR} type=point geometry="geom_2" -o --o
> > v.in.ogr -r input="PG:dbname=psql_local" layer=${DBSCHEMA}.${DATASET}
> > out=gr_${DATASET}_${REFYEAR} type=point geometry="geom_2" -o --o #2990
> > vertices registered
> > #clipping with same region after loading reduces to "1079 primitives
> > registered"
> > v.clip in=gr_${DATASET}_${REFYEAR} out=gr_${DATASET}clip_${REFYEAR} -r
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190226/332380e9/attachment.html>
