[GRASS-user] GUI not installed
Alessandro Sebastiani
alessandro.sebastiani at uniroma1.it
Wed Feb 27 00:53:57 PST 2019
i tried to follow your suggestion, but the problem was still there.
However, if i remove QGIS from my pc and than install GRASS, GUI is
present. I tried to re-install QGIS and, suddenly, the problem came out
again. Is it may due to a conflict between the latest QGIS version (3.6)
and the latest GRASS verision? I couldn't find any information,
thanks
A.
Il giorno mar 26 feb 2019 alle ore 16:57 Veronica Andreo <
veroandreo at gmail.com> ha scritto:
> Hi
> I think in Ubuntu you need to install gui separately, try with:
> sudo apt-get install grass-gui
> hth,
> vero
> El mar., 26 feb. 2019 a las 16:54, Alessandro Sebastiani (<
> alessandro.sebastiani at uniroma1.it>) escribió:
>> P.S i tried to upgrade using
>> > apt-get upgrade grass
>> but nothing changed
>> Il giorno mar 26 feb 2019 alle ore 17:47 Alessandro Sebastiani <
>> alessandro.sebastiani at uniroma1.it> ha scritto:
>>> Hello to everyone,
>>> these days i've been working on OS ubuntu 18.04.01. I generally use QGIS
>>> to visualize data and, suddenly , i had several broken packages and unmet
>>> dependencies (i probably messed something up trying to install a plug-in) ,
>>> so i had to completely remove and reinstall QGIS. However, since that
>>> moment GRASS GUI seems to be disappeared. I can start GRASS from the
>>> terminal, however when i try to start GUI using
>>> > g.gui wxpython
>>> i got the following message:
>>> GRASS 7.4.0 (mask_32n):~ > g.gui wxpython
>>> ERROR: Your installation doesn't include GUI, exiting.
>>> Can someone help me??
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190227/7b2bbaba/attachment.html>
