[GRASS-user] v.out.ogr - layer name
Markus Metz
markus.metz.giswork at gmail.com
Sat Jan 5 08:04:30 PST 2019
On Fri, Jan 4, 2019 at 4:04 PM Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 3/01/19 15:13, Daniel McInerney wrote:
> > Hi List,
> > When I export a vector using v.out.ogr, I'm unable to assign an output
> > layer name when the output format is 'ESRI_Shapefile'. For example:
> > v.out.ogr input=grid_clip output=grid_clip.shp output_layer=sub_grid
> > format='ESRI_Shapefile'
> > Exporting 4 areas (may take some time)...
> > 100%
> > v.out.ogr complete. 4 features (Polygon type) written to <sub_grid>
> > the message indicates that it has been written to sub_grid, but the
> > output from ogrinfo indicates that is hasn't been updated:
> > ogrinfo -so grid_clip.shp
> > INFO: Open of `grid_clip.shp'
> > using driver `ESRI Shapefile' successful.
> > 1: grid_clip (Polygon)
> > However, the above process works, and the correct layer name is written,
> > when the output format is GeoPackage or SQLite. I can update the layer
> > name subsequently with ogr2ogr, but it would be preferable if this could
> > be avoided. I'm using GRASS 7.4.0 (2018) on Ubuntu 18.04 (bionic).
> > Any advice appreciated.
> I don't think shapefile supports the notion of layer names as each layer
> is in a separate file, so file = layer, and filename = layername.
For shapefiles, the datasource name is the folder and the layer name is the
name of the actual shapefile without .shp.
The output option of v.out.ogr defines the datasource name. OGR handles
shapefiles a bit special, i.e. the output layer name with .shp is accepted
as output datasource name where the layer name is also defined.
For example
/path/to/grid_clip.shp
the datasource name is /path/to, the layer name is grid_clip, and
datasource and layer name can be set together with /path/to/grid_clip.shp.
This is OGR specific, not GRASS specific.
> v.out.ogr could possibly be enhanced by including a warning about this
> when the user tries to assigne a layer name to a shapefile.
Assigning a layer name to an output shapefile works just fine with e.g.
v.out.ogr output=/path/to output_layer=sub_grid
Markus M
> Moritz
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190105/9c1b2507/attachment.html>
