[GRASS-user] v.vol.rst - not enough disk space to write temp file
Francois Chartier
fra.chartier at gmail.com
Mon Jan 14 17:13:14 PST 2019
grass data is on the external drive, see screenshot attached.
freespace on external drive 1.77TB
what is interesting with the external drive is the temp file does not
really explode in size like if files are on laptop:
it has been running for about 50 min now.
I changed the region, made the domain slightly smaller and used a lower
resolution:100x100x5
g.region
(Mon Jan 14 19:26:20 2019)
g.region n=4875000 s=4820000 e=680000 w=585000 t=350 b=50 nsres=100
ewres=100 tbres=5
(Mon Jan 14 19:26:21 2019) Command finished (0 sec)
for some reason it seems that i have 2 nsres and ewres
C:\Users\Francois Chartier>g.region -p3
projection: 1 (UTM)
zone: 17
datum: nad83
ellipsoid: grs80
north: 4875000
south: 4820000
west: 585000
east: 680000
top: 350.00000000
bottom: 50.00000000
nsres: 100
nsres3: 5
ewres: 100
ewres3: 5
tbres: 5
rows: 550
rows3: 11000
cols: 950
cols3: 19000
depths: 60
cells: 522500
cells3: 12540000000
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virus-free.
www.avast.com
<#m_-995905413045375258_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Le dim. 13 janv. 2019 à 08:52, Markus Neteler <neteler at osgeo.org> a écrit :
> Hi,
> On Sat, Jan 12, 2019 at 11:56 PM Francois Chartier
> <fra.chartier at gmail.com> wrote:
> > Hi,
> > I checked the temp file that is saved during the v.vol.rst interpolation
> process, and the file went up to over 50 GB and more until the space on my
> laptop (free space of 100GB) was exausted.
> I start to wonder if those tmp files created are in any way compressed
> (probably not?). This may be worth a bug ticket at
> https://trac.osgeo.org/grass/newticket
> > So I copied all the grass data file onto an external hard drive with 1
> Terabyte of space. started grass and browsed to the data that is
> > saved on the external hard drive. when running vvolrst, the process
> also crashed due to not enough space....
> > the memory situation is much better during the process.
> > for some reason it does not seem to increase the size of the temp file
> on the hard drive...
> So the grassdata directory with the location and mapset in question is
> on the terabyte disk?
> > see error message below.
> > (Sat Jan 12 17:28:02 2019)
> > v.vol.rst --overwrite input=Dec16CleanedJjan12 at Toronto wcolumn=dbl_2
> dmin=1 elevation=dec16jan12
> > 280957 records selected from table
> > WARNING: Some points outside of region -- will ignore...
> > Processing all selected output files will require 2134724556 bytes of
> disk space for temp files
> > WARNING: There are points outside specified 2D/3D region--ignored 1
> points (total points: 280957)
> > WARNING: Points are more dense than specified 'DMIN'--ignored 158199
> points (remain 122758)
> > WARNING: Unable to create 'cross_output' raster map without
> 'cross_input' raster map being specified
> > ERROR: Not enough disk space - cannot write temp files
> I think we should try to improve the error message, telling on which
> device this occurs.
> The code in question is:
> vector/v.vol.rst/main.c, line 633
> /* filling temp file with zeroes */
> for (i = 0; i < n_rows; i++) {
> if (!
> (fwrite
> (zero_array_cell, sizeof(FCELL), n_cols,
> Tmp_fd_cell))) {
> clean();
> G_fatal_error(_("Not enough disk space - cannot
> write temp files"));
> Does anyone know how to get a better error message?
> Would this help?
> https://linux.die.net/man/3/explain_fwrite
> > (Sat Jan 12 17:54:14 2019) Command finished (26 min 12 sec)
> > below is the g.region -p3 printed, as you can see this is a large domain
> and high resolution.
> > projection: 1 (UTM)
> > zone: 17
> > datum: nad83
> > ellipsoid: grs80
> > north: 4924870
> > south: 4784003
> > west: 585000
> > east: 679717
> > top: 453.00000000
> > bottom: 2.16080000
> > nsres: 50.00603479
> > nsres3: 5.00007099
> > ewres: 50.00897571
> > ewres3: 5.00010558
> > tbres: 0.999643458980044
> Are the pixels/voxels non-square on purpose? This could be adjusted
> with g.region.
> > rows: 2817
> > rows3: 28173
> > cols: 1894
> > cols3: 18943
> > depths: 451
> > cells: 5335398
> > cells3: 240690193689
> That is still a lot (just guessing around):
> 240,690,193,689 raster3d_cells * 64 bit (but it will be larger than
> 32bit) = 1.540417e+13 bit
> So, in the first place we need to know where GRASS GIS really writes
> to in your system.
> Any devs having a suggestion here?
> Markus
Virus-free.
www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190114/b04aba21/attachment-0001.html>
Name: external drive.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190114/b04aba21/attachment-0001.jpg>
