[GRASS-user] v.vol.rst - not enough disk space to write temp file
Francois Chartier
fra.chartier at gmail.com
Tue Jan 15 05:31:15 PST 2019
i will try with a smaller model domain to see if the size of the domain the
source of the problem.
On Mon, Jan 14, 2019, 20:19 Francois Chartier <fra.chartier at gmail.com wrote:
> it finally finished the process. the files size that was created on the
> external disk was 50GB as you can see on the attached screenshot.
> the interpolation took 49 min to complete.
> (Mon Jan 14 19:28:05 2019)
> v.vol.rst input=Dec16CleanedJjan12 at Toronto wcolumn=dbl_2 dmin=2
> elevation=dec16jan14
> 280957 records selected from table
> WARNING: Some points outside of region -- will ignore...
> WARNING: Strip exists with insufficient data
> Processing all selected output files will require 836000000 bytes of disk
> space for temp files
> WARNING: There are points outside specified 2D/3D region--ignored 55094
> points (total points: 280957)
> WARNING: Points are more dense than specified 'DMIN'--ignored 156188
> points (remain 124769)
> WARNING: Unable to create 'cross_output' raster map without 'cross_input'
> raster map being specified
> (Mon Jan 14 20:17:49 2019) Command finished (49 min 43 sec)
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virus-free.
> www.avast.com
> <#m_-6629092632311730313_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> Le lun. 14 janv. 2019 à 20:13, Francois Chartier <fra.chartier at gmail.com>
> a écrit :
>> grass data is on the external drive, see screenshot attached.
>> freespace on external drive 1.77TB
>> what is interesting with the external drive is the temp file does not
>> really explode in size like if files are on laptop:
>> it has been running for about 50 min now.
>> I changed the region, made the domain slightly smaller and used a lower
>> resolution:100x100x5
>> g.region
>> (Mon Jan 14 19:26:20 2019)
>> g.region n=4875000 s=4820000 e=680000 w=585000 t=350 b=50 nsres=100
>> ewres=100 tbres=5
>> (Mon Jan 14 19:26:21 2019) Command finished (0 sec)
>> for some reason it seems that i have 2 nsres and ewres
>> C:\Users\Francois Chartier>g.region -p3
>> projection: 1 (UTM)
>> zone: 17
>> datum: nad83
>> ellipsoid: grs80
>> north: 4875000
>> south: 4820000
>> west: 585000
>> east: 680000
>> top: 350.00000000
>> bottom: 50.00000000
>> nsres: 100
>> nsres3: 5
>> ewres: 100
>> ewres3: 5
>> tbres: 5
>> rows: 550
>> rows3: 11000
>> cols: 950
>> cols3: 19000
>> depths: 60
>> cells: 522500
>> cells3: 12540000000
>> www.avast.com
>> <#m_-6629092632311730313_m_288032140617036686_m_-995905413045375258_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>> Le dim. 13 janv. 2019 à 08:52, Markus Neteler <neteler at osgeo.org> a
>> écrit :
>>> Hi,
>>> On Sat, Jan 12, 2019 at 11:56 PM Francois Chartier
>>> <fra.chartier at gmail.com> wrote:
>>> > Hi,
>>> > I checked the temp file that is saved during the v.vol.rst
>>> interpolation process, and the file went up to over 50 GB and more until
>>> the space on my laptop (free space of 100GB) was exausted.
>>> I start to wonder if those tmp files created are in any way compressed
>>> (probably not?). This may be worth a bug ticket at
>>> https://trac.osgeo.org/grass/newticket
>>> > So I copied all the grass data file onto an external hard drive with 1
>>> Terabyte of space. started grass and browsed to the data that is
>>> > saved on the external hard drive. when running vvolrst, the process
>>> also crashed due to not enough space....
>>> > the memory situation is much better during the process.
>>> > for some reason it does not seem to increase the size of the temp file
>>> on the hard drive...
>>> So the grassdata directory with the location and mapset in question is
>>> on the terabyte disk?
>>> > see error message below.
>>> > (Sat Jan 12 17:28:02 2019)
>>> > v.vol.rst --overwrite input=Dec16CleanedJjan12 at Toronto wcolumn=dbl_2
>>> dmin=1 elevation=dec16jan12
>>> > Processing all selected output files will require 2134724556 bytes of
>>> disk space for temp files
>>> > WARNING: There are points outside specified 2D/3D region--ignored 1
>>> > WARNING: Points are more dense than specified 'DMIN'--ignored 158199
>>> points (remain 122758)
>>> 'cross_input' raster map being specified
>>> > ERROR: Not enough disk space - cannot write temp files
>>> I think we should try to improve the error message, telling on which
>>> device this occurs.
>>> The code in question is:
>>> vector/v.vol.rst/main.c, line 633
>>> /* filling temp file with zeroes */
>>> for (i = 0; i < n_rows; i++) {
>>> if (!
>>> (fwrite
>>> (zero_array_cell, sizeof(FCELL), n_cols,
>>> Tmp_fd_cell))) {
>>> clean();
>>> G_fatal_error(_("Not enough disk space - cannot
>>> write temp files"));
>>> Does anyone know how to get a better error message?
>>> Would this help?
>>> https://linux.die.net/man/3/explain_fwrite
>>> > (Sat Jan 12 17:54:14 2019) Command finished (26 min 12 sec)
>>> > below is the g.region -p3 printed, as you can see this is a large
>>> domain and high resolution.
>>> > projection: 1 (UTM)
>>> > zone: 17
>>> > datum: nad83
>>> > ellipsoid: grs80
>>> > north: 4924870
>>> > south: 4784003
>>> > west: 585000
>>> > east: 679717
>>> > top: 453.00000000
>>> > bottom: 2.16080000
>>> > nsres: 50.00603479
>>> > nsres3: 5.00007099
>>> > ewres: 50.00897571
>>> > ewres3: 5.00010558
>>> > tbres: 0.999643458980044
>>> Are the pixels/voxels non-square on purpose? This could be adjusted
>>> with g.region.
>>> > rows: 2817
>>> > rows3: 28173
>>> > cols: 1894
>>> > cols3: 18943
>>> > depths: 451
>>> > cells: 5335398
>>> > cells3: 240690193689
>>> That is still a lot (just guessing around):
>>> 240,690,193,689 raster3d_cells * 64 bit (but it will be larger than
>>> 32bit) = 1.540417e+13 bit
>>> So, in the first place we need to know where GRASS GIS really writes
>>> to in your system.
>>> Any devs having a suggestion here?
>>> Markus
>> www.avast.com
>> <#m_-6629092632311730313_m_288032140617036686_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190115/f1cc5dc5/attachment.html>
