[GRASS-user] v.vol.rst interpolation results in rectangular isosurfaces
Francois Chartier
fra.chartier at gmail.com
Sat Jan 26 10:42:40 PST 2019
Using v.vol.rst, (see command below, and g.region), the interpolation
results in rectangular areas in certain areas, see attached photo.
Does this have to do with the segmentation process or something else?
v.vol.rst --overwrite input="Dec16CleanedJjan12 at Toronto" wcolumn="db\ |
| l_2" tension=10 smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=0.1
ws\ |
| cale=1.0 zscale=1.0 elevation="jan25"
(Sat Jan 26 13:37:21 2019) Command finished (0 sec)
(Sat Jan 26 13:37:44 2019)
r3.info map=Jan25 at Toronto
| Layer: Jan25 at Toronto Date: Fri Jan 25 22:12:59 2019
| Mapset: Toronto Login of Creator: Francois
Charti |
| DataBase: C:\Users\Francois Chartier\Documents\grassdata
| Title: jan25
| Units: none
| Vertical unit: units
| Timestamp: none
| Type of Map: raster_3d Number of Categories: 0
| Data Type: FCELL
| Rows: 400
| Columns: 450
| Depths: 65
| Total Cells: 11700000
| Total size: 27646661 Bytes
| Number of tiles: 1575
| Mean tile size: 17553 Bytes
| Tile size in memory: 32400 Bytes
| Number of tiles in x, y and z: 15, 15, 7
| Dimension of a tile in x, y, z: 30, 27, 10
| Projection: UTM (zone 17)
| N: 4837000 S: 4833000 Res: 10
| E: 632500 W: 628000 Res: 10
| T: 115 B: 50 Res: 1
| Range of data: min = -25.42733002 max = 121.86579132
| Data Source:
| Data Description:
| generated by v.vol.rst
| Comments:
wcolumn="db\ |
ws\ |
(Sat Jan 26 13:37:45 2019) Command finished (0 sec)
C:\Users\Francois Chartier>g.region -p3
projection: 1 (UTM)
zone: 17
datum: nad83
ellipsoid: grs80
north: 4837000
south: 4833000
west: 628000
east: 632500
top: 115.00000000
bottom: 50.00000000
nsres: 10
nsres3: 10
ewres: 10
ewres3: 10
tbres: 1
rows: 400
rows3: 400
cols: 450
cols3: 450
depths: 65
cells: 180000
cells3: 11700000
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virus-free.
www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190126/b468e679/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190126/b468e679/attachment-0001.jpg>
