[GRASS-user] v.vol.rst interpolation results in rectangular isosurfaces
Francois Chartier
fra.chartier at gmail.com
Thu Jan 31 17:34:01 PST 2019
i will do that. i think also as there is denilevation in that area, some
of the voxels are above ground which creates these 'empty' areas.
On Thu, Jan 31, 2019, 02:25 Markus Metz <markus.metz.giswork at gmail.com
wrote:
> On Sat, Jan 26, 2019 at 7:43 PM Francois Chartier <fra.chartier at gmail.com>
> wrote:
> > Hi,
> > Using v.vol.rst, (see command below, and g.region), the interpolation
> results in rectangular areas in certain areas, see attached photo.
> > Does this have to do with the segmentation process or something else?
> Most probably yes, try to increase npmin. Maybe you also need to increase
> segmax, but segmax should not be increased without increasing npmin,
> otherwise you might get more of these block artefacts.
> Markus M
> > v.vol.rst --overwrite input="Dec16CleanedJjan12 at Toronto" wcolumn="db\
> > | l_2" tension=10 smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=0.1
> ws\ |
> > | cale=1.0 zscale=1.0 elevation="jan25"
> > (Sat Jan 26 13:37:21 2019) Command finished (0 sec)
> > (Sat Jan 26 13:37:44 2019)
> > r3.info map=Jan25 at Toronto
> > | Layer: Jan25 at Toronto Date: Fri Jan 25 22:12:59
> 2019 |
> > | Mapset: Toronto Login of Creator: Francois
> Charti |
> > | Location: Toronto
> > | DataBase: C:\Users\Francois Chartier\Documents\grassdata
> > | Title: jan25
> > | Units: none
> > | Vertical unit: units
> > | Timestamp: none
> > | Type of Map: raster_3d Number of Categories: 0
> > | Data Type: FCELL
> > | Rows: 400
> > | Columns: 450
> > | Depths: 65
> > | Total Cells: 11700000
> > | Total size: 27646661 Bytes
> > | Number of tiles: 1575
> > | Mean tile size: 17553 Bytes
> > | Tile size in memory: 32400 Bytes
> > | Number of tiles in x, y and z: 15, 15, 7
> > | Dimension of a tile in x, y, z: 30, 27, 10
> > | Projection: UTM (zone 17)
> > | N: 4837000 S: 4833000 Res: 10
> > | E: 632500 W: 628000 Res: 10
> > | T: 115 B: 50 Res: 1
> > | Range of data: min = -25.42733002 max = 121.86579132
> > | Data Source:
> > | Data Description:
> > | generated by v.vol.rst
> > | Comments:
> wcolumn="db\ |
> ws\ |
> > (Sat Jan 26 13:37:45 2019) Command finished (0 sec)
> > C:\Users\Francois Chartier>g.region -p3
> > projection: 1 (UTM)
> > zone: 17
> > datum: nad83
> > ellipsoid: grs80
> > north: 4837000
> > south: 4833000
> > west: 628000
> > east: 632500
> > top: 115.00000000
> > bottom: 50.00000000
> > nsres: 10
> > nsres3: 10
> > ewres: 10
> > ewres3: 10
> > tbres: 1
> > rows: 400
> > rows3: 400
> > cols: 450
> > cols3: 450
> > depths: 65
> > cells: 180000
> > cells3: 11700000
> > Virus-free. www.avast.com
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190131/931aa4fc/attachment.html>
