[GRASS-user] Build error: git repo master
Markus Metz
markus.metz.giswork at gmail.com
Thu Jul 18 09:15:29 PDT 2019
On Thu, Jul 18, 2019 at 5:58 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Thu, 18 Jul 2019, Markus Metz wrote:
> >> Aha! On my systems there's libgeos-3.7.2.so.
> > yes, that's the error. Either "make distclean" or if that does not help
> > figure out if there are two different GEOS installations, then remove
one
> > of them. Also check where libgeos.so is and where it points to.
> Markus M,
> After each build (or attempt) I run 'make distclean.'
> There's only geos-3.7.2 installed.
> On the 64-bit systems the libraries are in /usr/lib64/.
> libgeos.so points to libgeos-3.7.2.so
> so, I'll make a new softlink pointing libgeos-3.7.0.so to libgeos.so
that does not make sense to me. Other software/libraries also link against
geos, e.g. gdal, maybe one of those needs to be updated because of updated
geos. Is "gdalinfo --formats" working?
Markus M
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190718/fdfcd8d9/attachment.html>
