[GRASS-user] Points to area workflow
Thomas Adams
tea3rd at gmail.com
Sun Jul 21 13:45:53 PDT 2019
Micha & Rich:
I was able to successfully import & display the boundary from Rich's
example:
v.in.ascii --overwrite
input=/media/teaiii/development/grass/test_analysis_boundary.dat
output=test_analysis_boundary format=standard separator=space
I used GRASS 7.6 with the GUI, but the command above worked...
Tom
On Sun, Jul 21, 2019 at 3:03 PM Micha Silver <tsvibar at gmail.com> wrote:
> On 7/21/19 9:08 PM, Rich Shepard wrote:
> Micha,
> There is a space preceeding each coordinate and layer line. The VERTI and
> object type start in column 1 while the other lines start in column 2.
> I'm getting the same error as you. Maybe you found a bug?
> I removed both the " 1 1" lines, and also rearranged the points so that
> they go in order around the boundary. (I wasn't paying attention,
> previously they made an "X").
> micha at RMS tmp $ cat analysis_boundary.dat
> VERTI:
> B 5
> -123.960 45.1501
> -123.940 45.1501
> -123.940 45.1454
> -123.960 45.1454
> -123.960 45.1501
> C 1
> -123.950 45.1475
> micha at RMS tmp $ v.in.ascii input=~/work/tmp/analysis_boundary.dat
> output=analysis_boundary format=standard --o
> Building topology for vector map <analysis_boundary at PERMANENT>...
> Registering primitives...
> Building areas...
> 100%
> Attaching islands...
> 100%
> Attaching centroids...
> 100%
> micha at RMS tmp $ v.info analysis_boundary
> | Name:
> analysis_boundary |
> | Mapset:
> PERMANENT |
> | Location:
> WGS84 |
> | Database:
> /home/micha/GIS/grass |
> Title: |
> | Map scale:
> 1:1 |
> | Name of creator:
> micha |
> Organization: |
> | Source date: Sun Jul 21 21:48:47
> 2019 |
> | Timestamp (first layer):
> none |
> | Map format:
> native |
> | Type of map: vector (level:
> 2) |
> | Number of points: 0 Number of centroids:
> 1 |
> | Number of lines: 0 Number of boundaries:
> 1 |
> | Number of areas: 1 Number of islands:
> 1 |
> | Map is 3D:
> No |
> | Number of dblinks:
> 0 |
> | Projection:
> Latitude-Longitude |
> | N: 45:09:00.36N S:
> 45:08:43.44N |
> | E: 123:56:24W W:
> 123:57:36W |
> | Digitization threshold:
> 0 |
> Comment: |
> micha at RMS tmp $ g.version
> GRASS 7.6.1 (2019)
> Note that you now have a geometry with no category column. So next will
> have to be
> v.category option=add ....
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
Thomas E Adams, III
1724 Sage Lane
Blacksburg, VA 24060
tea3rd at gmail.com (personal)
tea at terrapredictions.org (work)
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190721/ad2be3ea/attachment-0001.html>
