[GRASS-user] Points to area workflow
Markus Metz
markus.metz.giswork at gmail.com
Mon Jul 22 01:32:00 PDT 2019
On Sun, Jul 21, 2019 at 7:01 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
so you want to define a boundary with 5 coordinates and no categories: that
is
B 5
and make sure you do not define a category for the boundary
and a centroid with one coordinate and one category
C 1 1
therefore remove the line with " 1 1" in the boundary definition
> analysis_points.dat:
> VERTI:
> B 5 # There are 5 coordinates and no categories
> -123.940000 45.150100
> -123.940000 45.145400
> -123.960000 45.150100
> -123.960000 45.145400
--> remove
> 1 1
--> change
> C 1
C 1 1
> -123.950000 45.147500
> 1 1
you get then
B 5 # 5 coordinates and no categories
C 1 1 # 1 coordinate and one category
1 1
this conforms now to the GRASS ASCII vector format specification, in
particular
TYPE NUMBER_OF_COORDINATES [NUMBER_OF_CATEGORIES]
and should import successfully
Markus M
> GRASS now fails to import the data file:
> v.in.ascii in=analysis_points.dat out=analysis_corners for=standard --o
> WARNING: Error reading ASCII file: (unknown type) [ 1 1]
> ERROR: Import failed
> Grass seems to not like the layer and category number for the centroid as
> removing those for the boundary produces the same error.
> What am I still missing?
> Regards,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190722/80482ac6/attachment.html>
