[GRASS-user] Extensions
marie-joëlle desgagné mjdesgagne at hotmail.com
Mon Jul 22 10:32:30 PDT 2019
Hi, I found a way to modify the path on the g.extension script to find the source codes of the tools I want to use and it worked.
I am now trying to launch the script Watershed_GRASS but I get an error message saying that my module is built against version $Revision$ but trying to use version $Revision: 72327 $. I need to rebuild GRASS GIS or untangle multiple installations.
I am not used to programing so I don't really know how to deal with this situation.
Thank you very much
Marie-Joëlle Desgagné
De : grass-user <grass-user-bounces at lists.osgeo.org> de la part de Helmut Kudrnovsky <hellik at web.de>
Envoyé : 16 juillet 2019 08:53
À : grass-user at lists.osgeo.org <grass-user at lists.osgeo.org>
Objet : Re: [GRASS-user] Extensions
marie-joëlle desgagné wrote
> Hi, I am currently using Grass Gis version 7.6.1.
> I want to add the plug in: r.stream.basins. For that to occur I tried to
> go in g.extension and install it, but I get this error message:
> Downloading precompiled GRASS Addons
> <r.stream.basins>
> ERROR: Extension
> <r.stream.basins>
>  not found
> It looks like none of the extensions can be found.
> Thank you!
which operating system?
see
https://lists.osgeo.org/pipermail/grass-commit/2019-July/045534.html
adapting the addon system after the git switch is still a work in progress.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190722/15051ca0/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190722/15051ca0/attachment.txt>
