[GRASS-user] error in g.extension, add-ons not written in GUI
Veronica Andreo
veroandreo at gmail.com
Tue Jul 23 09:50:56 PDT 2019
Hi Anna,
Thanks for your answer.
El vie., 19 jul. 2019 a las 6:09, Anna Petrášová (<kratochanna at gmail.com>)
escribió:
> Could you create a ticket for this with info on Python version, locale
> etc.? This happens with any addon? (at least couple randomly tried ones)
Sorry for the late response, since it's not my laptop, I could only collect
the data needed today.
Pls, see the ticket #3874 (https://trac.osgeo.org/grass/ticket/3874)
Thanks much in advance!
Vero
> On Thu, Jul 18, 2019 at 9:49 AM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hi all,
>> I just compiled grass77 in a Linux Mint 19.1 Cinamon laptop following the
>> instructions here:
>> https://grasswiki.osgeo.org/wiki/Compile_and_Install#Linux_Mint
>> All is fine, but when we install any add-on, we get:.
>> g.extension r.seasons
>> Fetching <r.seasons> from GRASS GIS Addons repository (be patient)...
>> Compiling...
>> Installing...
>> Updating addons metadata file...
>> Updating private addons metadata file...
>> Traceback (most recent call last):
>> File
>> "/home/carla/software/grass-7.7.git/dist.x86_64-pc-linux-gnu/scripts/g.extension",
>> line 1933, in <module>
>> sys.exit(main())
>> File
>> line 1913, in main
>> install_extension(source=source, url=url, xmlurl=xmlurl)
>> File
>> line 704, in install_extension
>> blist = install_private_extension_xml(tmp_dir, mlist)
>> File
>> line 1006, in install_private_extension_xml
>> write_xml_modules(xml_file, tree)
>> File
>> line 603, in write_xml_modules
>> (' ' * indent, tnode.find('keywords').text))
>> UnicodeEncodeError: 'ascii' codec can't encode character u'\xe1' in
>> position 19: ordinal not in range(128)
>> GRASS 7.7.dev (nc_basic_spm_grass7):~ > g.extension extension=v.class.mlR
>> Fetching <v.class.mlR> from GRASS GIS Addons repository (be patient)...
>> Compiling...
>> Installing...
>> File
>> sys.exit(main())
>> File
>> line 1913, in main
>> File
>> File
>> File
>> UnicodeEncodeError: 'ascii' codec can't encode character u'\xf3' in
>> position 29: ordinal not in range(128)
>> The add-on is indeed installed, but it is not added to the list of
>> extensions in the GUI. Is there something we are missing here or in the
>> instructions for Mint?? I cannot reproduce in my Fedora box with freshly
>> re-compiled grass77
>> Any hint is wellcome :)
>> Cheers,
>> Vero
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190723/dd3e7212/attachment.html>
