[GRASS-user] r.hazard.flood extension
Margherita Di Leo
diregola at gmail.com
Fri Jun 7 01:44:20 PDT 2019
On Fri, Jun 7, 2019 at 12:16 AM Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, May 24, 2019 at 6:36 PM Martin Landa <landa.martin at gmail.com>
> wrote:
> > Hi,
> > pá 24. 5. 2019 v 15:48 odesílatel Margherita Di Leo <diregola at gmail.com>
> napsal:
> > > as far as I remember, it worked only in projected coordinate system.
> > 1) should be mentioned in manual at least
> +1 - TODO
Done
> > >> Traceback (most recent call last):
> > >> File "/home/lara/.grass7/addons/scripts/r.hazard.flood", line 145, in
> <module>
> > >> sys.exit(main())
> > >> File "/home/lara/.grass7/addons/scripts/r.hazard.flood", line 78, in
> main
> > >> resolution = (float(dict_region['nsres']) +
> float(dict_region['ewres']))/2
> > >> ValueError: invalid literal for float(): 0:00:00.17656
> > 2) should faill more gracefully. LL location is not supported.
> https://github.com/OSGeo/grass-addons/pull/4
Thank you Markus.
Cheers,
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190607/35b91ab5/attachment.html>
