[GRASS-user] Fwd: Re: remove small islands from vector areas
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Fri Jun 21 05:18:55 PDT 2019
Ah, OK. Got that wrong, sorry.
I don`t think holes have an area (but I may be wrong)....
So you might have to add a centroid first?
https://grass.osgeo.org/grass76/manuals/v.centroids.html
Cheers
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Robert Nuske
Sent: fredag 21. juni 2019 13:49
To: grass-user <grass-user at lists.osgeo.org>
Subject: [GRASS-user] Fwd: Re: remove small islands from vector areas
-------- Weitergeleitete Nachricht --------
Betreff: Re: [GRASS-user] remove small islands from vector areas
Datum: Fri, 21 Jun 2019 13:47:52 +0200
Von: Robert Nuske <rsn.mailinglists at gmail.com>
An: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Hi Stefan,
as far as I understood does rmarea that remove small areas but not islands (holes) within areas. At least i didn't find a way to remove islands with v.clean.
thanks
robert
Am 21.06.19 um 13:06 schrieb Stefan Blumentrath:
> Hi Robert,
> Did you have a look at v.clean:
> https://grass.osgeo.org/grass77/manuals/v.clean.html
> with
> tool=rmarea >
> Cheers
> Stefan
> Robert Nuske
> Sent: fredag 21. juni 2019 12:33
> Subject: [GRASS-user] remove small islands from vector areas
> Dear Listers,
> sorry, it's me again.
> I want to remove islands smaller than a certain threshold from my vector map or if that is not possible all islands.
> I found some trick on an old manual page of v.extract. But this does not work anymore. Is there a new trick?
> thnaks
> robert
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
