[GRASS-user] Import gpkg point map
Markus Metz
markus.metz.giswork at gmail.com
Wed Jun 26 13:03:53 PDT 2019
On Wed, Jun 26, 2019 at 4:58 PM Micha Silver <tsvibar at gmail.com> wrote:
> I am trying to import some geopackage files. Some are polygons, and one
is a points vector. The polygons import fine, but the point vector fails
with:
> ERROR: Detected different projections of input layers. Input layers must
be
> imported separately.
> Then if I convert the gpkg to a shapefile, it works fine.
> Any ideas what could be wrong? Here's the procedure, showing the problem.
> # Now The point gpkg vector:
> micha at TP480:Ashalim$ ogrinfo ashalim_train_pts.gpkg ashalim_train_pts
are there any other layers in ashalim_train_pts.gpkg?
You can check with
ogrinfo -so ashalim_train_pts.gpkg
> # Try import
> micha at TP480:Ashalim$ v.import ashalim_train_pts.gpkg output=ashalim_pts
--o
be
be
> ERROR: Unable to create location from OGR datasource
> <ashalim_train_pts.gpkg>
There must be more than one layer in ashalim_train_pts.gpkg, maybe an empty
layer?
> If anyone wants the point and polygon gpkg files to test, I can share it.
For testing, I would only need the point gpkg file.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190626/94d2edfb/attachment.html>
