[GRASS-user] Import gpkg point map
Markus Metz
markus.metz.giswork at gmail.com
Wed Jun 26 13:44:51 PDT 2019
On Wed, Jun 26, 2019 at 10:16 PM Micha Silver <tsvibar at gmail.com> wrote:
> On 26/06/2019 23:03, Markus Metz wrote:
> On Wed, Jun 26, 2019 at 4:58 PM Micha Silver <tsvibar at gmail.com> wrote:
> > I am trying to import some geopackage files. Some are polygons, and one
is a points vector. The polygons import fine, but the point vector fails
with:
> > ERROR: Detected different projections of input layers. Input layers
must be
> > imported separately.
> > Then if I convert the gpkg to a shapefile, it works fine.
> > Any ideas what could be wrong? Here's the procedure, showing the
problem.
> > # Now The point gpkg vector:
> > micha at TP480:Ashalim$ ogrinfo ashalim_train_pts.gpkg ashalim_train_pts
> are there any other layers in ashalim_train_pts.gpkg?
> You can check with
> ogrinfo -so ashalim_train_pts.gpkg
> micha at TP480:code$ ogrinfo -so ../GIS/Ashalim/ashalim_train_pts.gpkg
> INFO: Open of `../GIS/Ashalim/ashalim_train_pts.gpkg'
> using driver `GPKG' successful.
> 1: ashalim_train_pts (Point)
> 2: layer_styles (None)
> The style ??!!
> I removed that "layer_styles" table from the gpkg db, and deleted the
entry from gpkg_contents, and now the import works.
> Who would have guessed ?
> I suppose that I should have specified the layer in v.import to avoid
this problem.
Yes, specifying the layer should work.
I have seen this layer_styles layer before in other GPKG files but don't
know what this is good for. GDAL documentation at
https://gdal.org/drivers/vector/gpkg.html
does not mention any style information.
AFAICT, layers in a GPKG should contain vector geometries.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190626/b6b33c2d/attachment.html>
