[GRASS-user] r.li.mps
Alessandro Sebastiani
alessandro.sebastiani at uniroma1.it
Thu Jun 27 06:42:16 PDT 2019
Hello to everybody,
i tried to run r.li.mps module in order to perform mean patch size index
over a raster map. I used a raster with 4 values (1,2,3,4) rapresenting
different Land cover types. Some areas in my raster have nodata, since i'm
not planning to consider those in my work. I created the configuration
file, reported below:
SAMPLINGFRAME 0|0|1|1
SAMPLEAREA 0.0|0.0|1.0|0.9999541221268982
then i run the module over my raster, and here is the output:
RESULT 1|-7.1291406991691
I was not expecting this output, i can't figure out what's wrong.
___________________________________________
*Il tuo 5 diventa 1000*
Fai
crescere la tua università
Dona il 5 per mille alla Sapienza
Codice
fiscale: *80209930587*
https://www.uniroma1.it/it/pagina/fai-crescere-la-tua-universita-con-il-cinque-mille
<https://www.uniroma1.it/it/pagina/fai-crescere-la-tua-universita-con-il-cinque-mille>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190627/e14a73bc/attachment.html>
