[GRASS-user] Split polygons with lines
Shane Carey
careyshan at gmail.com
Fri Mar 15 07:41:57 PDT 2019
Hey Moritz,
Thanks for coming back to me. I figured it out with the following script
import processing
polys = QgsVectorLayer(r"C:\Users\shane.carey\Desktop\poly.shp", 'poly',
'ogr')
lines = QgsVectorLayer(r"C:\Users\shane.carey\Desktop\s1line.shp", 'lines',
'ogr')
output = r"C:\Users\shane.carey\Desktop\split2.shp"
processing.run("saga:polygonlineintersection",{ 'POLYGONS':polys,
'LINES':lines,'INTERSECT':output})
Cheers
Le gach dea ghui,
*Shane Carey*
*GIS and Data Solutions Consultant*
On Fri, Mar 15, 2019 at 2:21 PM Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 10/03/19 15:39, Shane Carey wrote:
> > Hi,
> > I've been looking for ways of grass gis splitting a polygon into
> > multiplepolygons with a line shapefile and wondering are there tools in
> > Grass to do this!!
> Does the following correspond to what you are looking for ?
> test = polygons
> test2 = lines
> # patch lines and polygons together
> v.patch test,test2 out=test_patched
> # transform lines to boundaries
> v.type test_patched out=test_patched_bound
> # break boundaries at intersections
> v.clean test_patched_bound tool=break out=test_patched_bound_clean
> # add centroids to new areas
> v.centroids test_patched_bound_clean out=final
> This can be easily scripted into a small addon module.
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190315/0e78a0d9/attachment.html>
