[GRASS-user] v.delaunay3d compilation issues
Robert Dzur rdzur at bhinc.com
Tue Mar 26 11:46:31 PDT 2019
Thank you Martin,
That appears to have resolved the issue as running g.extension again now reports successful installation:
Fetching <v.delaunay3d> from GRASS GIS Addons repository (be patient)...
Compiling...
ERROR: Variable 'LOCATION_NAME' not set
Installing...
Updating addons metadata file...
Installation of <v.delaunay3d> successfully finished
Thanks again,
Rob
Sent: Tuesday, March 26, 2019 12:29 PM
To: Robert Dzur
Cc: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] v.delaunay3d compilation issues
Ășt 26. 3. 2019 v 19:07 odesĂ­latel Robert Dzur <rdzur at bhinc.com> napsal:
> Yeah...I actually have libgdal-dev (2.4.0) package installed; and still see this issue.
check header location:
$ dpkg -L libgdal-dev | grep ogr_api
/usr/include/gdal/ogr_api.h
$ g.extension v.delaunay3d --v
c++ -Wdate-time -D_FORTIFY_SOURCE=2 -g -O2
-fdebug-prefix-map=/build/grass-8Jl1TI/grass-7.6.1=.
-specs=/usr/share/dpkg/no-pie-compile.specs -fstack-protector-strong
-Wformat -Werror=format-security  -I/usr/lib/grass76/include
-I/usr/lib/grass76/include   -frounding-math -DPACKAGE=\""grassmods"\"
 -I/usr/include/postgresql  -I/usr/lib/grass76/include
-DRELDIR=\"/tmp/grass7-martin-628/tmpHLuA32/v.delaunay3d\" -o
OBJ.x86_64-pc-linux-gnu/main.o -c main.cpp
so apparently `-I/usr/include/gdal` is missing. Should be fixed in
r74306. Try to run g.extension command again.
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190326/9f206351/attachment.html>
