[GRASS-user] error importing rasters
Alessandro Sebastiani alessandro.sebastiani at uniroma1.it
Thu Mar 28 06:17:33 PDT 2019
Thank you Veronica, it worked!
Il giorno gio 28 mar 2019 alle ore 13:14 Veronica Andreo <
veroandreo at gmail.com> ha scritto:
> Hi Alessandro,
> did you import the rasters in a newer version of GRASS, i.e., 7.6? It
> seems to me it is not recognizing the compression which is now by default
> in 7.6, but not in 7.4. I would try to get 7.6 installed again.
> For sure others know better
> best,
> Vero
> El jue., 28 mar. 2019 a las 12:38, Alessandro Sebastiani (<
> alessandro.sebastiani at uniroma1.it>) escribió:
>> hello to everyone,
>> when i try to import a raster (i tried more than one) i got the following
>> error (in this case i was importing an ndvi raster):
>> > Failed to run command 'd.rast map=ndvi_20180715 at alessandro'. Details:
>> GRASS_INFO_WARNING(2682,1): Request for unsupported compressor
>> GRASS_INFO_END(2682,1)
>> GRASS_INFO_WARNING(2682,2): Request for unsupported compressor
>> GRASS_INFO_END(2682,2)
>> GRASS_INFO_ERROR(2682,3): Request for unsupported compressor
>> GRASS_INFO_END(2682,3)
>> Failed to run command 'd.rast map=imd_2016_32n at alessandro'. Details:
>> GRASS_INFO_WARNING(2683,1): Request for unsupported compressor
>> GRASS_INFO_END(2683,1)
>> GRASS_INFO_WARNING(2683,2): Request for unsupported compressor
>> GRASS_INFO_END(2683,2)
>> GRASS_INFO_ERROR(2683,3): Request for unsupported compressor
>> GRASS_INFO_END(2683,3)
>> Failed to run command 'd.rast map=munpm10_average at alessandro'. Details:
>> GRASS_INFO_WARNING(2684,1): Request for unsupported compressor
>> GRASS_INFO_END(2684,1)
>> GRASS_INFO_WARNING(2684,2): Request for unsupported compressor
>> GRASS_INFO_END(2684,2)
>> GRASS_INFO_ERROR(2684,3): Request for unsupported compressor
>> GRASS_INFO_END(2684,3)
>> i run GRASS on UBUNTU 18.04.2 and i reistalled it yesterday since i was
>> having some troubles using GUI. I'm using version 7.4.0.
>> does anyone know what's wrong??
>> A.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190328/099af9cc/attachment-0001.html>
