[GRASS-user] r.watershed - Cleaning vector streams
Adrien André
adr.andre at laposte.net
Fri Mar 29 12:03:32 PDT 2019
Hello,
following the wiki doc about stream extraction [1], once the stream
layer thinned and vectorized,
there are many small arcs i would like to remove (see attached capture [2]).
So, with the underlying drainage direction map [3], and the resolution
r, i would like to delete segments
- about r*sqrt(2) long
- whose azimuth is more than 45° different from the pixel value under
its starting point.
But i still haven't figured a way to achieve this.
Do you have any advice ?
Thank you,
Best regards,
[1]
https://grasswiki.osgeo.org/wiki/Creating_watersheds#Display_first_results
[2] https://framapic.org/1exdxrdqxemw/ytuVxiBp2FKh.png
[3] https://grass.osgeo.org/grass74/manuals/r.watershed.html
Adrien
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190329/1af209f0/attachment-0001.png>
