[GRASS-user] r.watershed - Cleaning vector streams
    Adrien André
    adr.andre at laposte.net
    Sun Mar 31 13:20:00 PDT 2019
Thank you for your help,
i'll try r.stream.extract
I do have set a small threshold value but it is on purpose.
The streams i am trying to model are not hydrological.
Best regards,
Adrien
Le 19-03-31 à 09 h 48, Markus Metz a écrit :
> On Sat, Mar 30, 2019 at 5:30 PM Micha Silver <tsvibar at gmail.com
> <mailto:tsvibar at gmail.com>> wrote:
> > On 29/03/2019 22:03, Adrien André wrote:
> > Hello,
> > following the wiki doc about stream extraction [1], once the stream
> layer thinned and vectorized,
> > there are many small arcs i would like to remove (see attached
> capture [2]).
> > So, with the underlying drainage direction map [3], and the
> resolution r, i would like to delete segments
> > - about r*sqrt(2) long
> > - whose azimuth is more than 45° different from the pixel value
> under its starting point.
> > This might be possible, but I think the best approach would be to
> choose the correct threshold value for r.watershed from the start.
> > Trying to manually "fiddle" with the stream network will most likely
> leave you with disconnected segments, or other inconsistencies.
> +1
> Please try r.stream.extract in order to get a clean vector stream
> network. The approach r.thin + r.to.vect creates noise and does not
> always follow flow directions.
> Markus M
> > But i still haven't figured a way to achieve this.
> > Do you have any advice ?
> > Thank you,
> > Best regards,
> > [1]
> https://grasswiki.osgeo.org/wiki/Creating_watersheds#Display_first_results
> > [2] https://framapic.org/1exdxrdqxemw/ytuVxiBp2FKh.png
> > [3] https://grass.osgeo.org/grass74/manuals/r.watershed.html
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
> > Micha Silver
> > Ben Gurion Univ.
> > Sde Boker, Remote Sensing Lab
> > cell: +972-523-665918
Adrien
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190331/e2fcf0f8/attachment.html>
