[GRASS-user] Combining 2d rasters to 3d using point files
Francois Chartier fra.chartier at gmail.com
Wed May 1 05:00:12 PDT 2019
Are there any ideas how to run this process in batch mode for example?
On Thu., Apr. 25, 2019, 21:40 Francois Chartier, <fra.chartier at gmail.com>
wrote:
> Hi
> I would like to combine potentially 100s of 2d rasters into one 3d raster.
> Instead of using r.to.rast3 which could take a long time to prepare the
> setting, is there a way to export the raster as point files, and combine
> them using for example MsAccess, and then reimporting them into one 3d
> raster file?
> Alternatively, is it possible to combine several 3d raster into one 3d
> raster?  i could combine ten 2d rasters into one and then combine the
> multiple 3d rasters into one larger one.
> thks
> F
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190501/edd75636/attachment.html>
