[GRASS-user] mapcalc combining raster and vector
Moritz Lennert
mlennert at club.worldonline.be
Wed May 8 05:16:26 PDT 2019
On 8/05/19 14:00, Micha Silver wrote:
> You will most likely have to convert the points to raster. But before
> that, can you explain what you mean by "located for 10 m from DEM", "10
> to 20".
Or, if you mean zones of equal height, you can transform them to vector
polygons and use v.vect.stats on these polygons and the points.
Moritz
> On 08/05/2019 13:31, Francois Chartier wrote:
>> Hi
>> I would like to use mapcalc with types of input a DEM (raster) and xyz
>> property (vector). basically, I would like to do a weighted average
>> of data points located for 10 m from DEM, then 10 to 20 etc.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> +972-523-665918
