[GRASS-user] mapcalc combining raster and vector
Francois Chartier
fra.chartier at gmail.com
Fri May 10 17:16:35 PDT 2019
Sorry i realised later that in my current table i didnt rename the columns.
here are the extract from excel (300 K pts).
i am using the TopDepthRasterDEM_MASL as the Z elevation, and the attribute
i am interested in are Texture in mm and K in m/sec
BHID Zone EAST83 NORTH83 GTADEM MAT1 BOTDepthRasterDEM_MASL
TOPDepthRasterDEM_MASL TEXTURE_mm BH_Type K
11105041 17 580165.3 4873100 279.8977 SAND 277.7976701 279.59767 1.21
WWR
0.0000050
11105041 17 580165.3 4873100 279.8977 SAND 275.5976698 277.7976701
1.21 WWR
0.0000050
11105041 17 580165.3 4873100 279.8977 SAND 269.1976702 275.5976698
1.21 WWR
0.0000050
11105041 17 580165.3 4873100 279.8977 SAND 277.7976701 278 1.21 WWR
0.0000050
11105041 17 580165.3 4873100 279.8977 SAND 277.7976701 279 1.21 WWR
0.0000050
11105041 17 580165.3 4873100 279.8977 SAND 275.5976698 276 1.21 WWR
0.0000050
Le jeu. 9 mai 2019 à 22:45, Micha Silver <tsvibar at gmail.com> a écrit :
> OK, please clarify what each column reprepsents.
> On 10/05/2019 5:25, Francois Chartier wrote:
> V.DB.SELECT
> cat,int_1,int_2,dbl_1,dbl_2,dbl_3,str_1,dbl_4,dbl_5,dbl_6,str_2,dbl_7
> cat, bore_id??, ??, easting?, northing?, depth?, soil_type, ??, ??,
> bulk_density??, WWR ?, hydraulic_conduct??
> 1,11105041,17,580165.3,4873100,279.89767,SAND,277.7976701,279.59767,1.21,WWR,5e-006
> 2,11105041,17,580165.3,4873100,279.89767,SAND,275.5976698,277.7976701,1.21,WWR,5e-006
> 3,11105041,17,580165.3,4873100,279.89767,SAND,269.1976702,275.5976698,1.21,WWR,5e-006
> 4,11105041,17,580165.3,4873100,279.89767,SAND,277.7976701,278,1.21,WWR,5e-006
> 5,11105041,17,580165.3,4873100,279.89767,SAND,277.7976701,279,1.21,WWR,5e-006
> 6,11105041,17,580165.3,4873100,279.89767,SAND,275.5976698,276,1.21,WWR,5e-006
> 7,11105041,17,580165.3,4873100,279.89767,SAND,275.5976698,277,1.21,WWR,5e-006
> Le jeu. 9 mai 2019 à 04:59, Francois Chartier <fra.chartier at gmail.com> a
> écrit :
>> sure i will send that later. thks
>> On Thu., May 9, 2019, 04:00 Micha Silver, <tsvibar at gmail.com> wrote:
>>> On 08/05/2019 16:10, Moritz Lennert wrote:
>>> On 8/05/19 15:03, Francois Chartier wrote:
>>> Hi Micha,
>>> I have soil samples from boreholes where i have data points at every
>>> meter interval and where soil type changes. i would like to create a
>>> weighted average of soil property for lets say the first 1 m below the DEM,
>>> so that i can evaluate potential for infiltration across a watershed.
>>> You can use v.what.rast to read the DEM value into the attribute table
>>> of your points. Then you can do whatever calculations you need based on
>>> that.
>>> Moritz
>>> After Moritz's answer, It seems that your question is a data aggregation
>>> problem. If we can see the actual structure of your data (i.e. v.info -c
>>> or v.db.select then more specific responses might be possible. Best
>>> would be a small subset of the actual data.
>>> On Wed., May 8, 2019, 08:17 Moritz Lennert, <
>>> mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>
>>> <mlennert at club.worldonline.be>> wrote:
>>> On 8/05/19 14:00, Micha Silver wrote:
>>> > You will most likely have to convert the points to raster. But
>>> before
>>> > that, can you explain what you mean by "located for 10 m from
>>> DEM", "10
>>> > to 20".
>>> Or, if you mean zones of equal height, you can transform them to
>>> vector
>>> polygons and use v.vect.stats on these polygons and the points.
>>> Moritz
>>> > On 08/05/2019 13:31, Francois Chartier wrote:
>>> >> Hi
>>> >> I would like to use mapcalc with types of input a DEM (raster)
>>> and xyz
>>> >> property (vector). basically, I would like to do a weighted
>>> average
>>> >> of data points located for 10 m from DEM, then 10 to 20 etc.
>>> >> _______________________________________________
>>> >> grass-user mailing list
>>> >> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>> <grass-user at lists.osgeo.org>
>>> >> https://lists.osgeo.org/mailman/listinfo/grass-user
>>> > Micha Silver
>>> > Ben Gurion Univ.
>>> > Sde Boker, Remote Sensing Lab
>>> > +972-523-665918
>>> Micha Silver
>>> Ben Gurion Univ.
>>> cell: +972-523-665918
> Micha Silver
> Ben Gurion Univ.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190510/26148184/attachment-0001.html>
