[GRASS-user] turning sqlite journal off
Markus Metz markus.metz.giswork at gmail.com
Wed May 15 13:55:13 PDT 2019
On Tue, May 14, 2019 at 11:12 AM Panagiotis Mavrogiorgos <pmav99 at gmail.com>
wrote:
> Hi Laura,
> This thread seems to be related:
http://osgeo-org.1560.x6.nabble.com/SQLITE-db-locking-problem-td5182180.html
> I also had a somewhat similar problem that was related to the VACUUM
command issued when closing a GRASS session (new session started before the
VACUUM of the previous session was finished)
> If I understand this correctly, you are not supposed to concurrently use
the same sqlite database.
Yes, this is a limitation of sqlite, and the GRASS-internal sqlite driver
has been adapted accordingly as much as possible.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190515/a6dc2cbb/attachment.html>
