[GRASS-user] importing and cleaning overlapping polygons that are supposed to overlap
Veronica Andreo
veroandreo at gmail.com
Wed May 15 18:11:15 PDT 2019
Dear all,
thanks for the answers...
@Madi, I know, but that's how I got the data from a colleague using SaTScan
to get cluster sizes.
So, these "clusters" are 3, they are represented by circular areas and 2 of
them overlap, and it is just fine that they overlap. I just want one
centroid per area to be able to get one value per original area.
I tested your solution, @Micha (thanks much for your time!), but it gives
me 4 values, and I need 3. Moreover, I can no longer recognize which
polygon is which since v.db.select for layer 3 reports cats from 1 to 4,
but d.vect shows something different (I'd assume 2/3 has become 4?). See
screenshot below.
So, is it possible somehow to keep my 3 original polygons? And how can I
get raster values for my original 3 polygons in GRASS? Or is it that this
is not allowed by topology?
best,
Vero
[image: image.png]
El mié., 15 may. 2019 a las 12:04, Micha Silver (<tsvibar at gmail.com>)
escribió:
> On 15/05/2019 0:46, Veronica Andreo wrote:
> Hi all,
> I was working today with a very simple vector map which corresponds to
> clusters (circular polygons) that overlap and it is just fine that they
> overlap. So, i received a shapefile with 3 of these clusters. Two of them
> overlaped. When I import them into GRASS with v.import I get an extra
> centroid and area where 2 of the polygons overlap.
> Problem arises when I want to query a raster map with those polygons since
> originally the attribute table contained only 3 polygons (which is just
> fine). However, v.what.rast will only upload values for 2 of those three
> polygons because it finds 2 centroids with the same category, AFAIU.
> Here's how to get the raster values for all polygons (including those
> which are overlaps). It involves the somewhat non-intuitive process of
> creating another layer. I imported a simple polygon shapefile with three
> overlapping areas. Here are the categories:
> micha at TP480:~$ v.category polys opt=report
> Layer/table: 1/polys
> type count min max
> point 0 0 0
> line 0 0 0
> boundary 0 0 0
> centroid 12 1 3
> area 0 0 0
> face 0 0 0
> kernel 0 0 0
> all 12 1 3
> Layer: 2
> type count min max
> point 0 0 0
> line 0 0 0
> boundary 0 0 0
> centroid 4 2 3
> area 0 0 0
> face 0 0 0
> kernel 0 0 0
> all 4 2 3
> So, as you found, you get two layers, with all original areas split up at
> overlaps in layer 1, and just the overlap areas in layer 2. Now add a
> third layer, with new category values (option=add):
> micha at TP480:~$ v.category polys option=add layer=3 out=polys_3layers
> Layer/table: 1/polys_3layers
> type count min max
> point 0 0 0
> line 0 0 0
> boundary 0 0 0
> centroid 12 1 3
> area 0 0 0
> face 0 0 0
> kernel 0 0 0
> all 12 1 3
> Layer: 2
> type count min max
> point 0 0 0
> line 0 0 0
> boundary 0 0 0
> centroid 4 2 3
> area 0 0 0
> face 0 0 0
> kernel 0 0 0
> all 4 2 3
> Layer: 3
> type count min max
> point 0 0 0
> line 0 0 0
> boundary 0 0 0
> centroid 7 1 7
> area 0 0 0
> face 0 0 0
> kernel 0 0 0
> all 7 1 7
> This gives me three layers, and the new layer 3 has individual cat values
> for each polygon. So I'm ready to add a database table and column to that
> layer for the raster value, and then run v.what.rast:
> micha at TP480:~$ v.db.addtable polys_3layers layer=3 columns="rast_value
> DOUBLE"
> micha at TP480:~$ v.what.rast polys_3layers rast=dem_4m column=rast_value
> layer=3 type=centroid
> Reading features from vector map...
> Update vector attributes...
> 100%
> v.what.rast complete. 7 records updated.
> micha at TP480:~$ v.db.select polys_3layers layer=3
> cat|rast_value
> 1|488.3321
> 2|492.7044
> 3|481.2958
> 4|498.173
> 5|501.3336
> 6|493.2202
> 7|471.7223
> Does this help?
> I tried with
> v.clean input=clusters output=clusters_clean1 tool=break,rmdupl,rmsa,rmdac
> and
> v.clean input=clusters type=centroid output=clusters_clean2 tool=rmdupl
> but nothing seemed to do the kind of cleaning I wanted. I ended up using
> brute force and removing the extra centroid manually in the GUI. That
> helped with v.what.rast (all cats in the attr table were updated) but part
> of the original and correct geometry was clearly gone. I am sure that's not
> the right combination nor the right way either.
> In the wiki [0], I only found this piece of text: "If the *input polygons
> have logical errors*.... You can investigate overlapping areas in the
> imported vector with 'd.vect
> <https://grass.osgeo.org/grass76/manuals/d.vect.html> yourmap type=area
> layer=2' (only overlapping areas have a category in layer 2 after import).
> Additionally you may show the centroids of layer=2 to easier find tiny
> overlapping areas with 'd.vect
> type=centroid layer=2'"
> However, it says nothing about how to proceed further as to keep correctly
> overlapping polygons, each with its own centroid and remove the duplicated
> ones that are generated when importing.
> Can someone please share the set of steps that should be followed in these
> cases? Maybe it's a silly question, but I'm more a raster person so I am
> very easily lost with vector issues.
> Thanks much in advance!
> Vero
> [0] https://grasswiki.osgeo.org/wiki/Vector_topology_cleaning
> grass-user mailing listgrass-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190516/29b8db8d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190516/29b8db8d/attachment-0001.png>
