[GRASS-user] Multiple errors building Grass 7.7svn
Markus Metz markus.metz.giswork at gmail.com
Wed May 22 08:57:02 PDT 2019
On Wed, May 22, 2019 at 5:33 PM Patton, Eric (NRCan/RNCan) <
eric.patton at canada.ca> wrote:
> Markus -
> Yes, I am using proj 6.0.0 – built with no errors.
be aware that GRASS might compile with PROJ 6, but it is not working, too
much has changed from PROJ 5 and all those changes are not yet considered
in GRASS. Most importantly, coordinate transformations might produce wrong
results.
Furthermore, GRASS will most likely not support PROJ 6.0, only PROJ 6.1+,
because of bug fixes and important new functionality.
> I believe I checked out master with ‘git clone
https://github.com/OSGeo/grass.git’ – so shouldn’t that fix already be
present in my source tree?
It depends when you updated master the last time. If in doubt, git pull
again.
Markus M
> ~ Eric.
> From: Markus Metz <markus.metz.giswork at gmail.com>
> Sent: May 22, 2019 12:25
> To: Markus Neteler <neteler at osgeo.org>
> Cc: Patton, Eric (NRCan/RNCan) <eric.patton at canada.ca>;
grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] Multiple errors building Grass 7.7svn
> On Wed, May 22, 2019 at 4:39 PM Markus Neteler <neteler at osgeo.org> wrote:
> > Hi Eric,
> > On Wed, May 22, 2019 at 3:32 PM Patton, Eric (NRCan/RNCan)
> > <eric.patton at canada.ca> wrote:
> > > Hi Markus,
> > > I noted your new installation instructions for the git repo and have
used those.
> > > The first error in error.log occurs in /usr/local/grass/lib/proj:
> > > test -d OBJ.x86_64-pc-linux-gnu || mkdir -p OBJ.x86_64-pc-linux-gnu
> > > gcc  -g -O2  -fPIC
 -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include
-I/usr/local/grass/dist.x86_64-pc-linux-gnu/include    -I/usr/local/include
-DPACKAGE=\""grasslibs"\"
-I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -DRELDIR=\"lib/proj\"
-o OBJ.x86_64-pc-linux-gnu/convert.o -c convert.c
> > > gcc  -g -O2  -fPIC
-o OBJ.x86_64-pc-linux-gnu/datum.o -c datum.c
> > > gcc  -g -O2  -fPIC
-o OBJ.x86_64-pc-linux-gnu/do_proj.o -c do_proj.c
> > > gcc  -g -O2  -fPIC
-o OBJ.x86_64-pc-linux-gnu/ellipse.o -c ellipse.c
> > > do_proj.c: In function ‘GPJ_init_transform’:
> > > do_proj.c:136:6: error: expected ‘}’ before ‘else’
> > >       else {
> > > do_proj.c: At top level:
> > > do_proj.c:160:5: error: expected identifier or ‘(’ before ‘if’
> > >      if (info_trans->pj == NULL)
> > > do_proj.c:162:5: error: expected identifier or ‘(’ before ‘if’
> > >      if (info_trans->pj == NULL) {
> > > do_proj.c:167:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
‘__attribute__’ before ‘->’ token
> > >      info_trans->meters = 1.;
> > > do_proj.c:168:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> > >      info_trans->zone = 0;
> > > do_proj.c:169:23: error: expected ‘)’ before ‘->’ token
> > >      sprintf(info_trans->proj, "pipeline");
> > > do_proj.c:180:5: error: expected identifier or ‘(’ before ‘return’
> > >      return 1;
> > > do_proj.c:181:1: error: expected identifier or ‘(’ before ‘}’ token
> > > ../../include/Make/Compile.make:32: recipe for target
'OBJ.x86_64-pc-linux-gnu/do_proj.o' failed
> > > make: *** [OBJ.x86_64-pc-linux-gnu/do_proj.o] Error 1
> > > make: *** Waiting for unfinished jobs....
> > ok, there seems to be a problem with the PROJ installation.
> No, it's a problem with the #ifdef's in do_proj.c accounting for
different versions of PROJ
> > Which proj version do you use? Please post the names of the related
> > packages here which you have installed (so that we see the precise
> > version names).
> This must be PROJ 6.
> do_proj.c should be fixed in master 7c3e8de:
https://github.com/OSGeo/grass/commit/7c3e8de11b877f7c6240b5f94868ec27464d6c9f
> Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190522/ffeca6f8/attachment-0001.html>
