[GRASS-user] r.contour contour wrap
Mark Seibel mseibel at gmail.com
Wed May 22 09:15:08 PDT 2019
just FYI.
I am (was?) using 7.6 and had errors with r.contour outputs (linux mint).
Output lines would be broken in areas there was good DEM data. The lines
had large gaps between some isolines where other software could make clean
contour from the DEM.
I downloaded and compiled 7.7 and works great.
On Thu, May 3, 2018 at 4:29 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, May 3, 2018 at 10:17 PM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
> > On Tue, May 1, 2018 at 9:57 PM, Markus Metz <
> > wrote:
> > Thanks for providing test data! There was indeed a bug in r.contour,
> fixed
> > in trunk r72668. Is it OK to backport the bugix to GRASS 7.4 and 7.2?
> ... in terms of backport policy definitely yes.
> markusN
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190522/41ddd806/attachment-0001.html>
