[GRASS-user] get raster name in r.series min/max
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Sat May 25 22:19:37 PDT 2019
Hei Vero,
Use min_raster and max_for raster method in r.series...
Did you try that?
Cheers
Stefan
From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of Veronica Andreo <veroandreo at gmail.com>
Sent: Sunday, May 26, 2019 6:02:47 AM
To: Frank David
Cc: grass-user
Subject: Re: [GRASS-user] get raster name in r.series min/max
Hi Frank
El sáb., 25 may. 2019 22:51, Frank David <frank.david at geophom.fr<mailto:frank.david at geophom.fr>> escribió:
Hi all,
I would like to identify the raster, in a r.series calculation for min
(or max), where the result is coming from.
Is there a way to do so ?
max_raster, min_raster in r.series will give you the index of the raster map in the series containing either max or min values
Is that what you need?
Vero
Thank you
Frank
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190526/93429435/attachment.html>
