[GRASS-user] get raster name in r.series min/max
Frank David frank.david at geophom.fr
Mon May 27 06:04:33 PDT 2019
Hello,
Thank you very much Vero and Micha, It's exactly what I was looking for
! That's great !
Cheers,
Frank
Le 26/05/2019 à 12:11, Micha Silver a écrit :
> On 26/05/2019 7:02, Veronica Andreo wrote:
>> Hi Frank
>> El sáb., 25 may. 2019 22:51, Frank David <frank.david at geophom.fr
>> <mailto:frank.david at geophom.fr>> escribió:
>>     Hi all,
>>     I would like to identify the raster, in a r.series calculation
>>     for min
>>     (or max), where the result is coming from.
>>     Is there a way to do so ?
>> max_raster, min_raster in r.series will give you the index of the
>> raster map in the series containing either max or min values
>> Is that what you need?
>> Vero
> Hello Frank:
> I used Vero's suggestion in a script I was working on some months ago:
> I had a list of rasters, each represented a "station_id". I used
> g.list to create the list of raster names, and fed that into r.series
> input=<list> method=max_raster.
> Then I used r.reclass to get back the station_id from the list index.
> I had a text file with matches between the index of the raster in the
> list, and it's actual "station_id". So r.reclass returned a raster
> with each pixel value being the station_id of the maximum raster in
> the list.
> HTH
>>     Thank you
>>     Frank
>>     _______________________________________________
>>     grass-user mailing list
>>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190527/617246fc/attachment.html>
