[GRASS-user] grass-user Digest, Vol 157, Issue 33
Mehrdad Varedi varedi at gmail.com
Tue May 28 10:38:38 PDT 2019
Subject: Re: [GRASS-user] v.what.vect never ends, SQLite warning
Hi Everyone,
I think I figured out the problem.
I found that the problem was only the size or number of attributes in the
point layer when I dropped and reduced the attributes it worked very fast
and with no problem.
I am interested to know the limitations in GRASS GIS in terms of the number
of features or attributes, if there is any reference, please let me know.
Thanks,
Mehrdad
ᐧ
On Wed, May 22, 2019 at 7:07 PM <grass-user-request at lists.osgeo.org> wrote:
> Send grass-user mailing list submissions to
>         grass-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>    1. Re: v.what.vect never ends, SQLite warning (Mehrdad Varedi)
>    2. Average height over catchment in grass gis (Rengifo Ortega)
>    3. Re: importing and cleaning overlapping polygons that are
>       supposed to overlap (Moritz Lennert)
>    4. Re: importing and cleaning overlapping polygons that are
>       supposed to overlap (Veronica Andreo)
> Message: 1
> Date: Wed, 22 May 2019 16:20:21 -0400
> From: Mehrdad Varedi <varedi at gmail.com>
> To: grass-user <grass-user at lists.osgeo.org>
> Message-ID:
> CA+F3BSDW5cVJLFonj+SoKamo59K0XQCuW9QS1MDM9GYgTZoouw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Everyone,
> When I try v.what.vect on a point layer and the output of a v.voronoi,
> after around an hour I begin getting the warnings that apparently are
> because of an SQLite database lock.
> This is not what happens with v.what.vect only.
> When exporting the layer to shapefile or any other format it happens too.
> The point layer is not very big. it has 275,000 records and each has 350
> features (they are mostly double precision). The same happens with v.color
> on this layer.
> I have read feedback like, the SQLite doesn't like concurrent access on the
> same table, although I have restarted the computer, run only grass or tried
> to run it from R within GRASS and no other connection to that database
> existed, although the process takes forever and I begin getting the warning
> "Waiting for XXX seconds"
> Do you know how can I accelerate the processing or make it work?
> FYI, the CPU is not very busy more than 15-20% of its total capacity and
> the memory of 16GB is usually half free. The writing on disk is very
> minimal when it is working before the SQLite lock warning.
> Kind regards,
> Mehrdad
> ᐧ
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/grass-user/attachments/20190522/a2ed69a6/attachment-0001.html
> Message: 2
> Date: Wed, 22 May 2019 21:29:38 +0000 (UTC)
> From: Rengifo Ortega <rengifoo at yahoo.de>
> To: grass-user at lists.osgeo.org
> Subject: [GRASS-user] Average height over catchment in grass gis
> Message-ID: <2011043303.7503049.1558560578039 at mail.yahoo.com>
> Dear users  I am writting you here with the hope of getting some ideas
> about how to caculate what Kirsten Hennrich et al., refers to as average
> catchment height (Ha) I found this infomation in the proceedings of an
> international conference called regionalisation of hydrology.
> In page 184, he says that it is possible to calculate  Ha  using
> r.statistics in GRASS GIS (IAHS publication no. 254).
> I have been using sofar SAGA GIS to do the job.   But recently  I am
> experiencing some memory issues with SAGA GIS. In the old versions of  SAGA
> GIS  this calculation was named catchment height.  The new versions of SAGA
> GIS require that the user calculate  the mean over catchment  (MoC) first.
> Thereafter is MoC substrated from the original DTM. The product of this is
> the average catchment height or simply catchment height.
> Have someone in this group used GRASS GIS to calculate Catchment height in
> GRASS GIS. Any  hint will be appreciated.
> Best regardsRengifo Ortega
> URL: <
> http://lists.osgeo.org/pipermail/grass-user/attachments/20190522/49e1a001/attachment-0001.html
> Message: 3
> Date: Thu, 23 May 2019 00:15:16 +0200
> From: Moritz Lennert <mlennert at club.worldonline.be>
> To: Veronica Andreo <veroandreo at gmail.com>
> Cc: Markus Metz <markus.metz.giswork at gmail.com>, grass-user
>         <grass-user at lists.osgeo.org>, Micha Silver <tsvibar at gmail.com>
> Subject: Re: [GRASS-user] importing and cleaning overlapping polygons
>         that are supposed to overlap
> Message-ID: <20190523001516.07cd6c77 at moritz-ulb>
> Content-Type: text/plain; charset=UTF-8
> Le Wed, 22 May 2019 19:25:19 +0200,
> Veronica Andreo <veroandreo at gmail.com> a écrit :
> > Hi Markus,
> > Thanks for the explanation. It is possible to import topologically
> > incorrect vectors, but not create them within GRASS. So, as a
> > solution to my problem, I rather create (potentially overlapping)
> > buffers outside GRASS and import them with -c in v.in.ogr to use
> > v.rast.stats with no loss of areas, or follow the procedure that you
> > described earlier in the thread.
> You can also have a look at the v.rast.bufferstats addon.
> Moritz
> > Cheers,
> > Vero
> > El mié., 22 may. 2019 a las 18:48, Markus Metz (<
> > markus.metz.giswork at gmail.com>) escribió:
> > > On Wed, May 22, 2019 at 3:11 PM Veronica Andreo
> > > <veroandreo at gmail.com> wrote:
> > > > Dear all,
> > > > thanks again for your answers. I found an easier way, use -c flag
> > > > in
> > > v.in.ogr seems to not build topology of overlapping areas and then
> > > v.rast.stats does not complain.
> > > > However, if one builds buffer areas for points within GRASS,
> > > > i.e., using
> > > v.buffer, the problem appears again when buffer areas overlap,
> > > which it's pretty common when creating buffers around neighbouring
> > > points. Then, to get zonal stats for those areas the approach
> > > suggested by Markus Metz should be followed. I believe it is a bit
> > > of an overkill for such a common task in GIS. Couldn't v.buffer
> > > have a -c flag as v.in.ogr so when overlapping of buffer areas is
> > > fine the topology is not built and one would get just one area per
> > > input point? Would that be possible?
> > > In short, no.
> > > The reason is that with a topological vector model, areas are
> > > constructed from boundaries and centroids. If you use the -c flag
> > > of v.in.ogr and there are polygons that overlap to a large degree
> > > or completely, it is not possible to find a centroid for each
> > > topological area, i.e. the overlapping input polygons can not be
> > > properly represented with a topological model when using the -c
> > > flag. As soon as you get incorrect boundaries and/or duplicate
> > > centroids when building topology, results are wrong.
> > > Markus M
> > > > cheers,
> > > > Vero
> > > > El jue., 16 may. 2019 a las 11:27, Moritz Lennert (<
> > > mlennert at club.worldonline.be>) escribió:
> > > >> On 16/05/19 03:11, Veronica Andreo wrote:
> > > >> > Dear all,
> > > >> > thanks for the answers...
> > > >> > @Madi, I know, but that's how I got the data from a colleague
> > > >> > using SaTScan to get cluster sizes.
> > > >> > So, these "clusters" are 3, they are represented by circular
> > > >> > areas
> > > and 2
> > > >> > of them overlap, and it is just fine that they overlap. I just
> > > >> > want
> > > one
> > > >> > centroid per area to be able to get one value per original
> > > >> > area.
> > > >> > I tested your solution, @Micha (thanks much for your time!),
> > > >> > but it gives me 4 values, and I need 3. Moreover, I can no
> > > >> > longer recognize which polygon is which since v.db.select for
> > > >> > layer 3 reports cats
> > > from 1
> > > >> > to 4, but d.vect shows something different (I'd assume 2/3 has
> > > >> > become 4?). See screenshot below.
> > > >> To see the cat values of layer 3 you have to indicate that layer
> > > >> in the label_layer parameter (Labels tab).
> > > >> You can also see the correspondance between the two layers with
> > > >> v.category polys_3layers op=print layer=1,3
> > > >> > So, is it possible somehow to keep my 3 original polygons? And
> > > >> > how
> > > can I
> > > >> > get raster values for my original 3 polygons in GRASS? Or is
> > > >> > it that this is not allowed by topology?
> > > >> This depends on how you want to get raster values. If
> > > >> v.what.rast at the location of the centroid is all you need than
> > > >> Micha's solution should
> > > work.
> > > >> If you need v.rast.stats then you either have to use Markus'
> > > >> suggestion, or you use Micha's approach running v.rast.stats on
> > > >> layer three and then use some magic to transform the output of
> > > >> the above v.category call to a correspondance table between
> > > >> layer. Something like this
> > > >> import grass.script as g
> > > >> for feature in g.read_command('v.category',
> > > >>                               input_='polys_3layers',
> > > >>                               op='print',
> > > >>                                layer=[3,1]).splitlines():
> > > >>       cat1 = feature.split('|')[0]
> > > >>       cats2 = feature.split('|')[1].split('/')
> > > >>       for cat2 in cats2:
> > > >>           print cat1, cat2
> > > >> This correspondance table could then be used to aggregate the
> > > >> raster stats per (original) polygon in SQL. This could be the
> > > >> easily put into an addon module.
> > > >> Moritz
> > > > _______________________________________________
> Département Géosciences, Environnement et Société Université Libre de
> Bruxelles Bureau: S.DB.6.138
> CP 130/03
> Av. F.D. Roosevelt 50
> 1050 Bruxelles
> Belgique
> tél. + 32 2 650.68.12 / 68.11 (secr.)
> fax  + 32 2 650.68.30
> Message: 4
> Date: Wed, 22 May 2019 20:06:22 -0300
> From: Veronica Andreo <veroandreo at gmail.com>
> To: Moritz Lennert <mlennert at club.worldonline.be>
> Message-ID:
> CAAMki4GAFCMrQL-wWCFNFPjwnezv9MSevcyZPuYLDp1EBDygag at mail.gmail.com>
> Hi Moritz
> Thanks for the heads-up! Yes, for overlapping buffers v.rast.bufferstats
> seems just perfect! IIUC, it does exactly what MM was explaining. Great!
> Thanks again! And thanks Stefan for the add-on!
> Vero
> El mié., 22 may. 2019 19:30, Moritz Lennert <mlennert at club.worldonline.be>
> > > Hi Markus,
> > Moritz
> > > Cheers,
> > > Vero
> > > > > Dear all,
> > > > > in
> > > > > i.e., using
> > > > In short, no.
> > > > Markus M
> > > > > cheers,
> > > > > Vero
> > > > >> > Dear all,
> > > > >> > areas
> > > > and 2
> > > > >> > want
> > > > one
> > > > >> > area.
> > > > from 1
> > > > >> > how
> > > > can I
> > > > work.
> > > > >>                               op='print',
> > > > >>       for cat2 in cats2:
> > > > >>           print cat1, cat2
> > > > >> Moritz
> > CP 130/03
> > 1050 Bruxelles
> > Belgique
> URL: <
> http://lists.osgeo.org/pipermail/grass-user/attachments/20190522/6f32132a/attachment.html
> Subject: Digest Footer
> End of grass-user Digest, Vol 157, Issue 33
Mehrdad Varedi
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190528/9481118f/attachment-0001.html>
