[GRASS-user] WinGRASS build up (WIP)
Helmut Kudrnovsky hellik at web.de
Mon Nov 4 09:54:00 PST 2019
Hi Jürgen,
just updated my OSGeo4W in normal mode (not tick Exp), QGIS, GRASS 7.8.0, I'm getting an error that gdal300.dll and proj6.2.x.dlll is missing.
regards
Helmut
Gesendet: Montag, 04. November 2019 um 18:39 Uhr
Von: "Jürgen E. Fischer" <jef at norbit.de>
An: "Martin Landa" <landa.martin at gmail.com>
Cc: grass-user at lists.osgeo.org, qgis-developer at lists.osgeo.org, osgeo4w-dev at lists.osgeo.org, "Helmut Kudrnovsky" <hellik at web.de>
Betreff: Re: WinGRASS build up (WIP)
Hi Martin,
I added "experimental" packages to OSGeo4W (ie. only available if you tick Exp
in the OSGeo4W installer):
- PROJ 6.2.1
- GDAL 3.0.2
- liblwgeom 3.0.0
- OGDI 4.1.0
- Rebuilds of QGIS 3.10.0, QGIS 3.4.13 and spatialite 4.3.0a against the above
packages
- Backward compatibility packages gdal204dll and proj5dll that carry the original
DLLs from PROJ 5.2.0 and GDAL 2.4.1
The only missing bit is GRASS built against new GDAL and PROJ. Once that's is
available I can remove the "experimental" tag.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Juergen Fischer, Nils Kutscher HR: Amtsgericht Aurich HRB 100827
Datenschutzerklaerung: https://www.norbit.de/83/[https://www.norbit.de/83/]
