[GRASS-user] v.out.ogr and Date fields
Markus Metz
markus.metz.giswork at gmail.com
Wed Nov 6 07:52:20 PST 2019
On Wed, Nov 6, 2019 at 3:01 PM Markus Neteler <neteler at osgeo.org> wrote:
> Hi Daniel,
> On Mon, Nov 4, 2019 at 12:23 PM Daniel McInerney
> <daniel.o.mcinerney at gmail.com> wrote:
> > Hi List,
> > As part of a workflow, we are importing ESRI Shapefiles into GRASS so
> > that we can manage the vector topology, before re-exporting the vectors
> > back to an ESRI Shapefile. However, we noticed that the date fields are
> > being converted from a field of type Date to type String.
Indeed, this happens in v.out.ogr, should be easy to fix. Can you create a
ticket just as a reminder?
> AFAIK this is how SQLite handles it internally but the GRASS DBMI
> driver should take care of it to keep it in date format.
This has nothing to do with the sqlite driver.
Markus M
> > Hopefully the
> > following steps will demonstrate the issue:
> > The input Shapefile is scdb_date, with a date field called 'BA_DATE':
> > >ogrinfo -so -al scdb_date.shp | grep BA_DATE
> > BA_DATE: Date (10.0)
> > After importing into GRASS using v.in.ogr, the field is still of type
> > DATE (although the length has increased to 20):
> > >db.describe scdb_date | grep -A 5 BA_DATE
> > column:BA_DATE
> > description:
> > type:DATE
> > len:20
> > scale:0
> > precision:0
> > However, when I export the vector (scdb_date) back to an ESRI Shapefile
> > using v.out.ogr, the BA_DATE is converted to a String:
> > v.out.ogr input=scdb_date output=scdb_date_export.shp
> > format='ESRI_Shapefile'
> > >ogrinfo -so -al scdb_date_export.shp | grep 'BA_DATE'
> > BA_DATE: String (20.0)
> Probably the date detection failed in the grass-sqlite driver?
> Could it be an encoding problem?
> > I tried exporting to a GeoPackage, but the issue persists. While, we can
> > still overcome this issue using ogr and SQL, I am wondering if is there
> > a flag or option in v.out.ogr that I am overlooking that would maintain
> > the fields of type Date or is there something else that I should
consider?
> As this is unexpected could you make a small data sample available to
> easier reproduction?
> thanks
> Markus
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191106/be4424f2/attachment.html>
