[GRASS-user] 7.9.dev build issue
Rich Shepard rshepard at appl-ecosys.com
Tue Nov 12 11:11:04 PST 2019
On Tue, 12 Nov 2019, Markus Neteler wrote:
> Please check `config.log` for details.
Markus,
I should have attached that to my message.
I think that I see the error:
configure:7009: gcc -o conftest -g -O2  -O2 -fPIC  -I/usr/include -I/usr/include -I/usr/include -I/usr/include -I/usr/include  -Wl,--export-dynamic  -L/usr/lib64 conftest.c  -L/usr/lib -llas -llas_c -L/usr/lib64 /usr/lib64/libboost_program_options.so /usr/lib64/libboost_thread.so /usr/lib64/libgdal.so /usr/lib64/libgeotiff.so /usr/lib64/libtiff.so /usr/lib64/liblaszip.so 1>&5
/usr/lib64/gcc/x86_64-slackware-linux/5.5.0/../../../../x86_64-slackware-linux/bin/ld: warning: libgdal.so.20, needed by /usr/lib64/liblas.so, not found (try using -rpath or -rpath-link)
/usr/lib64/gcc/x86_64-slackware-linux/5.5.0/../../../../x86_64-slackware-linux/bin/ld: warning: libproj.so.13, needed by /usr/lib64/libgeotiff.so, not found (try using -rpath or -rpath-link)
/usr/lib64/liblas.so: undefined reference to `OGRSpatialReference::FixupOrdering()'
collect2: error: ld returned 1 exit status
This morning I upgraded to proj-6.2.1-x86_64-1_SBo, geos-3.8.0-x86_64-1_SBo,
and gdal-3.0.2-x86_64-1_SBo. And libLAS-1.8.1-x86_64-1_SBo is also
installed, but fails to rebuild.
Reading the liblas.org web page I think I should remove the liblas package
then build and install the pdal-1.9.1 package. Is this a good idea?
Regards,
Rich
