[GRASS-user] 7.9.dev build issue
    Rich Shepard
    rshepard at appl-ecosys.com
    Wed Nov 13 05:47:01 PST 2019
On Wed, 13 Nov 2019, Markus Neteler wrote:
> ^-- libgdal.so.20 not found
> However, since you use GDAL 3, the same is "libgdal.so.26".
Markus,
I could make a new softlink.
> (see https://github.com/OSGeo/grass/pull/191/files)
> Means, that liblas needs to be recompiled against the (new) GDAL
> installation on your machine.
That's what I tried to do, but liblas failed to build.
>> /usr/lib64/gcc/x86_64-slackware-linux/5.5.0/../../../../x86_64-slackware-linux/bin/ld: warning: libproj.so.13, needed by /usr/lib64/libgeotiff.so, not found (try using -rpath or -rpath-link)
> ^-- libproj.so.13 not found
> The same here: libgeotiff needs to be recompiled against the updated PROJ.
I recompiled libgeotiff but libgeospatialite failed to build; I've asked on
that mail list for help.
> Yes, it is important to recompile in the right order to keep up with the
> dependency tree (unless you install packages from the distro where these
> dependencies have been respected in the respective compile scripts).
Slackware doesn't automatically build dependencies nor build packages in a
defined sequence. Such tasks are left to the user and after many years I'm
well used to it.
Question: Yesterday I read that liblas has been deprecated in favor of pdal
and I have a vague recollection of reading (a mail message? a web page?)
that GRASS was accommodating this change. So I stopped trying to build
liblas, built and installed pdal, but could not get grass to incorporate it.
Will this transition be made reasonably soon?
Regards,
Rich
