[GRASS-user] 7.9.dev build issue
    Rich Shepard
    rshepard at appl-ecosys.com
    Wed Nov 13 07:24:07 PST 2019
On Wed, 13 Nov 2019, Markus Neteler wrote:
>> I could make a new softlink.
"Could" is the meaningful word. I did not do this.
> Yes, if the softlink was in place then it is expected.
See above.
> ok, so you need to compile probably in this order:
> - proj
> - geotiff
> - (other GDAL dependencies)
> - gdal
> - liblas (maybe outdated)
> - pdal
> - grass
I've always used proj -> geos -> gdal then other libraries. libLAS won't
build here.
> There is an open pull request for  GRASS core:
> "r.in.pdal - PDAL-based version of r.in.lidar"
> https://github.com/OSGeo/grass/pull/61
> As a workaround, there is an addon:
> https://grass.osgeo.org/grass7/manuals/addons/r.in.pdal.html
> which just requires the PDAL binary to be running.
I don't need either liblas or pdal now; not currently working with LiDAR
data.
Regards,
Rich
