[GRASS-user] Error launching GUI in Grass 7.8.1
Alessandro Sebastiani alessandro.sebastiani at uniroma1.it
Fri Nov 15 08:16:48 PST 2019
Hello to evenyone,
i have exactly the same problem that Eric Patton had. This morning suddenly
I got the same error message. I read the conversation and kind understood
that there is a file in grass78 that should be edited in order to fix the
error, however i did not notice where exactly this file is and how should I
edit it. Additionally, it only happened on my GRASS GIS installation for
Ubuntu in virtual machine, while the one on windows (Grass7.6) is still
working. Any suggestions? thank you,
A
Il giorno gio 14 nov 2019 alle ore 17:34 Eric Patton <
eric.r.patton at protonmail.com> ha scritto:
> Case closed! Thanks Markus, I made the edits, the GUI works fine.
> Cheers,
> Eric Patton
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> On Thursday, 14 November 2019 12:18, Markus Neteler <neteler at osgeo.org>
> wrote:
> > On Thu, Nov 14, 2019 at 5:13 PM Markus Neteler neteler at osgeo.org wrote:
> > > On Thu, Nov 14, 2019 at 4:49 PM Eric Patton
> > > eric.r.patton at protonmail.com wrote:
> > > > Hi Markus,
> > > > If you need the version number of specific libraries, let me know.
> I'm not sure which ones are relevant. I noticed that my python-wxtools and
> python-gtk libraries are version 3.0.2.
> > > Here on a Mint macine in the office we solved the
> > > "wx not found" problem with:
> > > sudo apt-get install python3-wxgtk4.0
> > > Now the 7.8.1 GUI starts.
> > > Next issue to solve is:
> > > "ImportError: cannot import name 'NewIdRef'
> > > So, we reached your bug at our end :-)
> > Haha, the backport to relbranch78 was missing:
> > now done in
> https://github.com/OSGeo/grass/commit/b7fb30a1da066e8864c8e36c5d55a93402e29dd0
> > This will go into GRASS GIS 7.8.2.
> > @Eric: you may simply edit the file locally to get it fixed without
> > waiting for 7.8.2.
> > Markus
> > Markus Neteler, PhD
> > https://www.mundialis.de - free data with free software
> > https://grass.osgeo.org
> > https://courses.neteler.org/blog
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
________________________________________________________
Le informazioni
contenute in questo messaggio di posta elettronica sono strettamente
riservate e indirizzate esclusivamente al destinatario. Si prega di non
leggere, fare copia, inoltrare a terzi o conservare tale messaggio se non
si è il legittimo destinatario dello stesso. Qualora tale messaggio sia
stato ricevuto per errore, si prega di restituirlo al mittente e di
cancellarlo permanentemente dal proprio computer.
The information
contained in this e mail message is strictly confidential and intended for
the use of the addressee only.  If you are not the intended recipient,
please do not read, copy, forward or store it on your computer. If you have
received the message in error, please forward it back to the sender and
delete it permanently from your computer system.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191115/570bedb9/attachment-0001.html>
