[GRASS-user] Basin DEM advice needed [RESOLVED]
Rich Shepard rshepard at appl-ecosys.com
Thu Oct 3 10:33:08 PDT 2019
On Wed, 2 Oct 2019, Rich Shepard wrote:
> I assume that I should resample each individual map, then re-run r.patch
> on the coarser maps because r.slope.aspect and r.info need a single map as
> input.
> Would this be an appropriate process? I'm completely open to all suggestions
> and recommendations.
Thanks to advice from several of you I've produced the results I need. I
resampled the patched DEM to 5m then generated slope and aspect maps. The
basin is so finely dissected (complex river network) that the curvature maps
do not communicate useful information.
Regards,
Rich
