[GRASS-user] v.kernel - Points weighted with attribute ?
Taïs tgrippa at ulb.ac.be
Tue Oct 22 04:33:34 PDT 2019
Hi Micha, thanks for your repply.
For my own need, I think your solution is enough and I would like to try
if you agree to send the R script.
Le 22/10/19 à 12:53, Micha Silver a écrit :
> On 10/21/19 1:33 PM, Tais wrote:
>> Hi all,
>> I would like to compute a raster density map ("heat map") from vector
>> points using v.kernel. The points represent house addresses. However,
>> I would need to weight the points with a value stored in the
>> attribute table (number of inhabitants). I saw on the module manual
>> page that this functionality is a "known issue".
>> I imagined a solution to by-passe the limitation: duplicate each
>> point as many time as needed (according to the value stored in the
>> attribute table) and use this new layer directly in v.kernel.
>> However, I think it will definitely not be the most efficient way to
>> do the trick. Do you have an alternative in mind ?
>> Of course the best solution would be that someone in the development
>> community would have the time and the kindness to implement this
>> function directly in the module (I'm not skilled in C and thus cannot
>> try myself).
> Maybe not the answer you are looking for, but you can create a
> weighted kernel density in R. I can send an R script that is intended
> to be run from within a GRASS session. It accepts a point vector and
> attrib column, and creates a kernel density raster, weighted by the
> attribute values (using the R defaults for bandwidth and Gaussian kernel)
> Requires, of course, that R is installed, with the packages: spatstat,
> raster, rgrass7.
>> NB: Sorry if I should have posted this on the developer mailing list.
>> I hesitated but decided to post here finally.
>> Best,
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191022/0d986974/attachment.html>
Une pièce jointe autre que texte a été nettoyée...
Nom: tgrippa.vcf
Type: text/x-vcard
Taille: 4 octets
Desc: non disponible
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191022/0d986974/attachment.vcf>
