[GRASS-user] v.kernel - Points weighted with attribute ?
Taïs tgrippa at ulb.ac.be
Mon Oct 28 05:08:58 PDT 2019
Hi Micha, Moritz,
I successfully create the kernel density raster. Thanks a lot for your
support ;)
I tried with ~62.000 points on a computational region of +- 1000 cols by
1000 rows, with 10 m. spatial resolution.
FYI, I had to change the type of the weights column from "double
precision" to "integer" because I had this error message when it was on
double precision:
/Error in matrix(rep(w, n[1]), nrow = n[1], ncol = nx, byrow
= TRUE) *  :
   non-numeric argument to binary operator
Calls: sp.kde -> fhat
Taïs
Le 25/10/19 à 13:36, Micha Silver a écrit :
> Hi Taïs
> Thanks for testing.
> As Moritz mentioned, the important parameter in spatial kernel density
> is the bandwidth.
> Here attached is an improved script that uses the spatialEco R package
> (instead of density.ppp from spatstat). To run this, you'll need to
> install spatialEco in your R environment.
> This package allows to specify both the bandwidth and the target
> raster extents and resolution. In this script I take the extents and
> resolution from the GRASS region. Bandwidth is specified on the
> command line.
> So to try this, in your running GRASS session:
> Rscript kernel_density.R <GRASS point vector> <weight column> <bandwidth>
> I also attached two images in a test I did, with bandwidths of 10,000
> and 20,000.
> Hope this helps,
> Micha
> On 10/25/19 12:17 PM, Taïs wrote:
>> Hi Micha,
>> I successfully run your R script. However to output is weird and I
>> don't know how to fix it.
>> In v.kernel, you can setup the "raduis" parameter to control what I
>> assume to be the size of the kernel (of the moving window). I made
>> one test with radius=300 and another with value 3000. The result of
>> the first is more what I would expect in terms of spatial variability.
>> When I try your script, the output raster has a size of 128x128 which
>> did not correspond at all to my computational region, and thus the
>> resolution is not the same as the one defined in the computational
>> region.
>> The other thing is that I'm wondering if it is possible to control
>> the size of the moving window with the "density" function in R. I
>> already tried the 'n' parameter but it doesn't change anything..
>> I also tried with real weights (the number of inhabitants) and a
>> unity weighting (value 1 for all points) to see it there is a change
>> and there is which proof the weights affect the output :)
>> Le 22/10/19 à 13:41, Micha Silver a écrit :
>>> Here is the script.
>>> Let me know how it goes. (I might try to take time to make it into a
>>> GRASS addon)
>>> On 10/22/19 2:33 PM, Taïs wrote:
>>>> Hi Micha, thanks for your repply.
>>>> For my own need, I think your solution is enough and I would like
>>>> to try if you agree to send the R script.
>>>> Le 22/10/19 à 12:53, Micha Silver a écrit :
>>>>> On 10/21/19 1:33 PM, Tais wrote:
>>>>>> Hi all,
>>>>>> I would like to compute a raster density map ("heat map") from
>>>>>> vector points using v.kernel. The points represent house
>>>>>> addresses. However, I would need to weight the points with a
>>>>>> value stored in the attribute table (number of inhabitants). I
>>>>>> saw on the module manual page that this functionality is a "known
>>>>>> issue".
>>>>>> I imagined a solution to by-passe the limitation: duplicate each
>>>>>> point as many time as needed (according to the value stored in
>>>>>> the attribute table) and use this new layer directly in v.kernel.
>>>>>> However, I think it will definitely not be the most efficient way
>>>>>> to do the trick. Do you have an alternative in mind ?
>>>>>> Of course the best solution would be that someone in the
>>>>>> development community would have the time and the kindness to
>>>>>> implement this function directly in the module (I'm not skilled
>>>>>> in C and thus cannot try myself).
>>>>> Maybe not the answer you are looking for, but you can create a
>>>>> weighted kernel density in R. I can send an R script that is
>>>>> intended to be run from within a GRASS session. It accepts a point
>>>>> vector and attrib column, and creates a kernel density raster,
>>>>> weighted by the attribute values (using the R defaults for
>>>>> bandwidth and Gaussian kernel)
>>>>> Requires, of course, that R is installed, with the packages:
>>>>> spatstat, raster, rgrass7.
>>>>>> NB: Sorry if I should have posted this on the developer mailing
>>>>>> list. I hesitated but decided to post here finally.
>>>>>> Best,
>>>>> Micha Silver
>>>>> Ben Gurion Univ.
>>>>> Sde Boker, Remote Sensing Lab
>>>>> cell: +972-523-665918
>>> Micha Silver
>>> Ben Gurion Univ.
> Micha Silver
> Ben Gurion Univ.
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191028/c47e5582/attachment.html>
Une pièce jointe autre que texte a été nettoyée...
Nom: tgrippa.vcf
Type: text/x-vcard
Taille: 4 octets
Desc: non disponible
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191028/c47e5582/attachment.vcf>
