[GRASS-user] v.in.gps issue
Thomas Adams
tea3rd at gmail.com
Sun Sep 1 16:11:25 PDT 2019
All:
I'm running GRASS 7.6.0, I built from source, on Ubuntu 19.04. No issues up
to this point. However, for the first time -ever-, I'm trying to use
v.in.gps:
v.in.gps -t input=/home/teaiii/Current.gpx output=slv_test_track
the Current.gpx file looks very reasonable (attached). When I run the above
command, I get no errors, but the slv_test_track vector file is not created
either -- no errors are generated. I installed GPSBabel *after* building
GRASS 7.6. Any thoughts what I'm doing or have done wrong?
Thank you,
Tom
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190901/a20226f1/attachment.html>
Type: application/gpx+xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190901/a20226f1/attachment.bin>
