[GRASS-user] WinGRASS addons partly back
Veronica Andreo
veroandreo at gmail.com
Wed Sep 4 07:52:04 PDT 2019
Hi Martin,
Thanks for your efforts. We just found, actually some students running
Windows in my tutorial at geostat today found, that some add-ons, those
that I need actually, are still failing... Here the error:
C:\OSGeo4W64\bin>g.extension v.strds.stats
ATTENZIONE: Extension <v.strds.stats> already installed. Re-installing...
Downloading precompiled GRASS Addons <v.strds.stats>...
Updating addons metadata file...
ERRORE: Unable to read manual page: [Errno 2] No such file or directory:
'C:\\Users\\cferr\\AppData\\Roaming\\GRASS7\\addons\\docs\\html\\v.strds.stats.html'
C:\OSGeo4W64\bin>g.extension v.in.pygbif
Downloading precompiled GRASS Addons <v.in.pygbif>...
'C:\\Users\\cferr\\AppData\\Roaming\\GRASS7\\addons\\docs\\html\\v.in.pygbif.html'
We checked the respective zip files on the wingrass server and in fact, the
HTML files are missing. From the log it is unclear to us why.
We tried with others such as v.in.gbif, v.what.rast.multi, r.hants,
r.seasons and r.bioclim and all them were properly installed in 7.6.1 under
windows. So, it seems something specific for those modules I pasted above
(and maybe some others, we didn't check them all).
Hope it can be solved... Otherwise, I'll have to change the exercises for
tomorrow morning's workshop :(
Vero
El mar., 3 sep. 2019 15:34, Martin Landa <landa.martin at gmail.com> escribió:
> Hi,
> after long time when WinGRASS builds were broken (since May 2019) I
> have some good news. I pushed yesterday locally built WinGRASS addons
> for latest GRASS stable release 7.6.1 (64bit only [1]). So the most
> urgent issue is solved somehow. Meanwhile I will be working on
> recovering whole daily builds infrastructure. I will keep you updated.
> Ma
> [1] https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/grass-7.6.1/logs/
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190904/d10b92df/attachment.html>
