[GRASS-user] sample a strds at specific locations (areas)
Margherita Di Leo
diregola at gmail.com
Fri Sep 6 01:53:05 PDT 2019
Please ignore my last email, this is not the case, I had vectors with
similar names in the current mapset. Sorry for confusion. Still struggling
on this.
On Wed, Sep 4, 2019 at 12:01 PM Margherita Di Leo <diregola at gmail.com>
wrote:
> Hi,
> I have an update on this. It seems to work if the vector file resides in
> the same mapset! I g.copied big_areas2 at PERMANENT to current mapset and
> the excluded polygons are much less. It surely needs further
> investigation...
> Kind regards,
> On Fri, Aug 9, 2019 at 4:50 PM Margherita Di Leo <diregola at gmail.com>
> wrote:
>> Hi,
>> excuse me if I return on this. I have again the same problem, of v.strds.stats
>> skipping lots of polygons. Now I'm using a brand new dataset - strds of
>> Sentinel 1 and a brand now vector of polygons - and the skipped polygons
>> are not narrow, I'm sure that there are cells centroids in it. See for
>> example screenshot attached, depicting a polygon that was skipped. I also
>> tried to run v.strds.stats on that polygon alone, like:
>> v.strds.stats in=big_areas2 at PERMANENT where="cat == '1'"
>> strds=db_cross_pol at scaled out=test method=average
>> v.info test
>> | Mapset: stats
>> | Location: S1
>> | Database: /media/madi/TOSHIBA EXT/S1/grassdata
>> | Title: Output from v.patch
>> | Map scale: 1:1
>> | Name of creator: madi
>> | Organization:
>> | Source date: Fri Aug 9 12:12:49 2019
>> | Timestamp (first layer): none
>> | Map format: native
>> | Type of map: vector (level: 2)
>> | Number of points: 0 Number of centroids: 0
>> | Number of lines: 0 Number of boundaries: 0
>> | Number of areas: 0 Number of islands: 0
>> | Map is 3D: No
>> | Number of dblinks: 0
>> | Projection: UTM (zone 34)
>> | N: 0 S: 0
>> | E: 0 W: 0
>> | Digitization threshold: 0
>> | Comment:
>> I confess I hadn't look much further into it because I thought it was a
>> problem with nodata, but this is not the case and I think it's worth of
>> further investigation. Thanks for any pointers.
>> Regards,
>> On Thu, Feb 7, 2019 at 4:10 PM Margherita Di Leo <diregola at gmail.com>
>> wrote:
>>> Thanks for testing, Vero. I assume it's due to a local problem then.
>>> Cheers,
>>> On Thu, Feb 7, 2019 at 3:29 PM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>>> Hi Stefan and Madi,
>>>> Thanks Stefan for the explanations :) Indeed I agree that a flag to
>>>> avoid the alignment to input rasters (and just use region settings) sounds
>>>> good.
>>>> I tested what Madi said, but cannot reproduce in the climate NC
>>>> location [0]. This is the command I used:
>>>> v.strds.stats in=boundary_county where="cat == '261'" strds=tempmean
>>>> t_where="start_time >= '2012-01-01'" out=test
>>>> to make it faster (it feels indeed kinda slow for the whole vector and
>>>> full time series), I selected only one polygon and a range of dates. I get
>>>> the table as expected while leaving methods by default.
>>>> best,
>>>> Vero
>>>> [0]
>>>> http://courses.ncsu.edu/mea592/common/media/02/nc_climate_spm_2000_2012.zip
>>>> El jue., 7 feb. 2019 a las 14:39, Margherita Di Leo (<
>>>> diregola at gmail.com>) escribió:
>>>>> Thank you Stefan for your help! I figured what happens. v.strds.stats
>>>>> with default method produces in my case a corrupted output, topology is
>>>>> there but there's no table associated to it. If I specify method=average, I
>>>>> do obtain the table, and the mystery is solved: some of the polygons fall
>>>>> into a nodata (due to cloud mask). If anyone else can reproduce the
>>>>> corrupted table issue, I can file a ticket for that.
>>>>> Thanks for help!
>>>>> Regards,
>>>>> On Thu, Feb 7, 2019 at 12:33 PM Stefan Blumentrath <
>>>>> Stefan.Blumentrath at nina.no> wrote:
>>>>>> Hi Madi,
>>>>>> With this combination (polygon size vs. raster resolution), the shape
>>>>>> of the polygons can be an issue (narrow areas that do not cover the center
>>>>>> of any pixel).
>>>>>> Debugging should be simple with v.db.select or v.extract.
>>>>>> Areas that did not get rasterized should be NULL in the column with
>>>>>> statistics computed with v.rast.stats.
>>>>>> In verbose mode v.rast.stats (or probably even v.to.rast) should
>>>>>> probably give a more informative Warning message (e.g. listing categories
>>>>>> not rasterized). It also would help if you can rasterize the areas yourself
>>>>>> and provide a raster with categories as (optional) input to v.rast.stats…
>>>>>> For high resolution data like yours, the speed improvement of
>>>>>> multiple raster input might help quite a bit esp. with many maps in the
>>>>>> time series. Will see if I can come up with a patch rather soon…
>>>>>> Cheers
>>>>>> Stefan
>>>>>> *From:* Margherita Di Leo <diregola at gmail.com>
>>>>>> *Sent:* torsdag 7. februar 2019 10:37
>>>>>> *To:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>
>>>>>> *Cc:* Veronica Andreo <veroandreo at gmail.com>; grass-user <
>>>>>> grass-user at lists.osgeo.org>
>>>>>> *Subject:* Re: [GRASS-user] sample a strds at specific locations
>>>>>> (areas)
>>>>>> Hi,
>>>>>> thank you for your replies. To give a little more context: I selected
>>>>>> my polygon areas to be > 0.5 ha each (this would be 50000 mq if I'm not
>>>>>> mistaken) and I'm sampling NDVI maps at 10m resolution (the region being
>>>>>> the same as NDVI maps). So I think I need an idea on how to debug the areas
>>>>>> that were excluded to check them individually to see what could be the
>>>>>> problem...
>>>>>> Regarding the alignment problem, if I understand it correctly: if the
>>>>>> polygon doesn't include the *center* of the raster beneath it, can't
>>>>>> retrieve the value and the polygon is discarded? But a value exists, so it
>>>>>> would be correct that it returned a value in any case. But I admit I don't
>>>>>> have a full grasp of the problem.
>>>>>> On Wed, Feb 6, 2019 at 10:52 PM Stefan Blumentrath <
>>>>>> Hi Vero,
>>>>>> I think there is a little misunderstanding.
>>>>>> v.rast.stats did not change it behaviour with regards to the
>>>>>> computational region (at least not if only one raster map is used). The
>>>>>> alignment to the input raster (resolution) has been around since the module
>>>>>> got ported to Python (like 10 years ago):
>>>>>> https://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.rast.stats/v.rast.stats.py?rev=33522#L148
>>>>>> So, adding a flag for skipping the alignment was more an idea for an
>>>>>> enhancement that allows the behaviour you seem to prefer (too).
>>>>>> Cheers
>>>>>> Stefan
>>>>>> *From:* Veronica Andreo <veroandreo at gmail.com>
>>>>>> *Sent:* onsdag 6. februar 2019 21:38
>>>>>> *Cc:* Margherita Di Leo <diregola at gmail.com>; grass-user <
>>>>>> (areas)
>>>>>> I had a similar problem some time ago, just that it was not raster
>>>>>> resolution, but region resolution that I changed to solve my problem (see
>>>>>> this thread and MM's answer:
>>>>>> http://osgeo-org.1560.x6.nabble.com/v-to-rast-for-polygons-not-overlapping-center-of-raster-cell-td5355686.html#a5355729
>>>>>> IIUC, MM's proposed solution to my case then does not work anymore
>>>>>> because v.to.rast call inside v.rast.stats is affected by the region
>>>>>> alignment to the raster to be queried. So, the solution is indeed now, to
>>>>>> change raster resolution... ? Then the region would be aligned to it (them)?
>>>>>> If one has large areas or long time series and has to resample all
>>>>>> rasters to get smallish polygons rasterized, I do not see the advantage of
>>>>>> this new behavior... but maybe I'm missing something
>>>>>> Cheers,
>>>>>> Vero
>>>>>> El mié., 6 feb. 2019 16:54, Stefan Blumentrath <
>>>>>> Stefan.Blumentrath at nina.no> escribió:
>>>>>> Ciao Madi, Vero,
>>>>>> Starting with GRASS 7.6, also centroids are used to get the raster
>>>>>> representation of your area vector map. That increases the likelihood of
>>>>>> smaller areas to be rasterized.
>>>>>> Increasing the resolution of the current region alone does not help,
>>>>>> because v.rast.stats temporarily changes the computational region to align
>>>>>> with the input raster map(s) (see also:
>>>>>> https://trac.osgeo.org/grass/ticket/3523 and
>>>>>> https://trac.osgeo.org/grass/ticket/3598 for discussion) Even if the
>>>>>> first ticket is closed, comments are welcome.
>>>>>> It might make sense to add a flag to v.rast.stats like in
>>>>>> r.slope.aspect to not align the computational region.
>>>>>> Furthermore, with regards to efficiency, v.strds.stats could gain
>>>>>> some speed if multi-raster support in v.rast.stats - added in G 7.6 - would
>>>>>> be handed down to the addon. Might almost double the speed for larger STRDS…
>>>>>> Cheers
>>>>>> Stefan
>>>>>> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf
>>>>>> Of *Veronica Andreo
>>>>>> *Sent:* onsdag 6. februar 2019 17:20
>>>>>> *To:* Margherita Di Leo <diregola at gmail.com>
>>>>>> *Cc:* GRASS user list <grass-user at lists.osgeo.org>
>>>>>> (areas)
>>>>>> Hi Madi
>>>>>> El mié., 6 feb. 2019 a las 16:31, Margherita Di Leo (<
>>>>>> I have a question regarding v.strds.stats. I get the following
>>>>>> warning message:
>>>>>> WARNING: Not all vector categories converted to raster. Converted 120
>>>>>> of 265.
>>>>>> What could be the reason for that?
>>>>>> Some vector areas might not be converted because they are too small
>>>>>> with respect to the pixel size that you try to query. Others will tell
>>>>>> better but I think the polygon must overlap the center of the pixel in
>>>>>> order to be converted into raster. One solution could be to resample your
>>>>>> rasters to a higher resolution.
>>>>>> HTH,
>>>>>> Vero
>>>>>> Margherita Di Leo
>>>>> Margherita Di Leo
>>> Margherita Di Leo
>> Margherita Di Leo
> Margherita Di Leo
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190906/19416570/attachment-0001.html>
