[GRASS-user] question exporting from grass GeoTif files
Gabriel Cotlier gabiklm01 at gmail.com
Mon Sep 9 10:51:02 PDT 2019
Dear Stefan,
Yes you are right ranges are correct.
Thanks a lot.
Gabriel
On Monday, September 9, 2019, Stefan Blumentrath <Stefan.Blumentrath at nina.no>
wrote:
> Hi Gabriel,
> I would be surprised if the data range is exported incorrectly (if you
> left autodetection of the data type to export to). Did you check the range
> of the data with:
> gdalinfo -mm F101992_c.tif
> Maybe it is just a display issue cause for example ArcGIS might just
> estimates the range…
> See otherwise also examples here for compatibility:
> https://grass.osgeo.org/grass76/manuals/r.out.gdal.html
> Cheers
> Stefan
> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of *Gabriel
> Cotlier
> *Sent:* mandag 9. september 2019 07:44
> *To:* grass-user <grass-user at lists.osgeo.org>; Markus Metz <
> markus.metz.giswork at gmail.com>; Nikos Alexandris <nik at nikosalexandris.net>;
> Veronica Andreo <veroandreo at gmail.com>
> *Subject:* [GRASS-user] question exporting from grass GeoTif files
> Dear grass users,
> I got after intercallibrarion the following layer (with a correct Range
> of data:    min = -0.3458  max = 61.9423 ) whats is the recommended way
> to get it exported out of grass to be opened in ArcGIS, conserving the
> range.
> When i do :
> [image: image.png]
> but, when I open the exported layer in ArcGIS the Range of values in
> modified...
> Thanks a lot for your help.
> Kid regards
> Gabriel
> [image:
> https://ipmcdn.avast.com/images/icons/icon-envelope-tick-round-orange-animated-no-repeat-v1.gif]
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon>
> Virus-free. www.avast.com
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190909/7fbf729f/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190909/7fbf729f/attachment.png>
