[GRASS-user] Install package for add-on in /usr/bin/python3
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Wed Apr 8 04:33:59 PDT 2020
Hi Robin,
After installing from python-fmask source as described I got the same error message as you did on:
from fmask import fmask
(just importing fmask worked also before).
The problem seems to be that fmask (including it`s C components) gets installed in /usr/local/. See:
https://github.com/ubarsc/python-fmask/issues/19
You can fix that by specifying /usr as a prefix during install:
sudo python3 setup.py install --prefix=/usr
(note that I also had to specifically call setup.py with python3 which was an error in my initial installation script.)
When python-fmask gets available on PyPi, I guess this will be taken care of…
If you set the PYTHONPATH environment variable before starting GRASS GIS, GRASS should temporarily add the path to the GRASS python libs (but nothing more). If you use a prepackaged GRASS installation, it is compiled against a specific Python version (usually system Python). You can see which Python installation GRASS is using by typing:
echo $GRASS_PYTHON
So, if you want to use your conda Python in GRASS (despite possible issues other places), my understanding is that you would need to point GRASS_PYTHON variable to conda python. However, with the installation described above, GRASS should find fmask and _fillminima from fmask… In the long run, this will be the most convenient solution for an addon. For the time being, the installation procedure could be added to the manual as a note (and probably as an error message if import fails), until it becomes available on PyPi.
Hope that helps.
Cheers
Stefan
Sent: søndag 5. april 2020 19:13
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Subject: Re: [GRASS-user] Install package for add-on in /usr/bin/python3
Hi Stefan,
thank you very much!! Why does my PYTHONPATH needs to point to the system-python? So the issue is, that I would like to have a script that I can run from within GRASS with launch user-defined script. I created a conda environment (“spatial”) and installed python-fmask with:
conda install -c conda-forge python-fmask
This automativally installes python3.8.2, fmask and rios in:
home/robin/miniconda3/envs/spatial/lib/python3.8/site-packages/
I then added this path in my .bashrc (I thought I needed to put it in the .profile, but this didn’t work for some reason) my PYTHONPATH with:
export PYTHONPATH=/home/robin/miniconda3/envs/spatial/lib/python3.8/site-packages
I then did a source .bashrc and when printing the PYTHONPATH with
echo $PYTHONPATH it prints
I then made a little test script where I wanted to test if the fmask-import and rios-import works
from within GRASS
1 #! /usr/bin/env python3
2
3 import sys
4 import os
5
6 for i in sys.path:
7 print(i)
8
9 print("PYTHONPATH")
10 print(os.environ["PYTHONPATH"])
11
12 import fmask
13 import rios
13 import rios
When importing this script in GRASS with the “launch user-defined script”-option, the output is:
/home/robin/Desktop
/usr/lib/grass78/etc/python
/usr/lib/python36.zip
/usr/lib/python3.6
/usr/lib/python3.6/lib-dynload
/home/robin/.local/lib/python3.6/site-packages
/usr/local/lib/python3.6/dist-packages
/usr/lib/python3/dist-packages
PYTHONPATH
File "/home/robin/Desktop/test.py", line 12, in <module>
import fmask
ModuleNotFoundError: No module named 'fmask'
I don’t know why the PYTHONPATH is different when run from GRASS. Probably I’m just not understanding something really basic. If so I’m really sorry. It’s just a little frustrating to spend so much time in something so basic.
Anyways: Thanks so much for the help!
Cheers,
Robin
On 05.04.2020 14:35, Stefan Blumentrath wrote:
Did you check that your pythonpath again points to system python. And can you share your code, esp. the imports. That would simplify testing...
Sent from Outlook Mobile<https://aka.ms/blhgte>
From: robin kohrs <robin.kohrs at uni-jena.de><mailto:robin.kohrs at uni-jena.de>
Sent: Sunday, April 5, 2020 11:04:02 AM
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no><mailto:Stefan.Blumentrath at nina.no>
Hi Stefan,
thank you very much for the answer! That would be great if it'd become a
standard python package!
I managed to install everything as you explained it. But when I run:
In [1]: from fmask import fmask
I still get
ModuleNotFoundError: No module named 'rios'
I guess this is, because they are still in seperate folders right?
When I copy everything from the installed rios into fmask (I know this
seems really wrong...) and then do :
In [2]: from fmask import fmask
ImportError: cannot import name '_fillminima'
I'm sorry for these basic questions, but I just can't find a solution:/
cheers and thanks a lot!!
Robin
On 04.04.20 20:56, Stefan Blumentrath wrote:
> Hi Robin,
> The errors you encountered after setting the python path, occurred because fmask depends on another, non-standard Python package, namely rios (that would have to be added to the PYTHONPATH as well).
> Yet, it seems there is some more interest in getting python-fmask (and thus also RIOS) available as a standard python package. See: https://github.com/ubarsc/python-fmask/issues/30
> So, your problem might get solved "upstreams".
> Meanwhile you could install both packages manually into your standard Python installation as follows:
> wget https://github.com/ubarsc/rios/releases/download/rios-1.4.10/rios-1.4.10.zip
> unzip rios-1.4.10.zip
> cd rios-1.4.10/
> sudo python setup.py install
> cd ..
> wget https://github.com/ubarsc/python-fmask/releases/download/pythonfmask-0.5.4/python-fmask-0.5.4.zip
> unzip -q python-fmask-0.5.4.zip
> cd python-fmask-0.5.4/
> python setup.py build
> For me (on Ubuntu 18.04) this gives:
> $ ipython
> Python 3.6.8 (default, Oct 7 2019, 12:59:55)
> Type 'copyright', 'credits' or 'license' for more information
> IPython 7.13.0 -- An enhanced Interactive Python. Type '?' for help.
> In [1]: import fmask
> In [2]: fmask.__version__
> Out[2]: '0.5.4'
> In [3]: import rios
> In [4]: rios.__version__
> Out[4]: '1.4.10'
> Cheers
> Stefan
> -----Original Message-----
> From: Robin Kohrs <robin.kohrs at uni-jena.de><mailto:robin.kohrs at uni-jena.de>
> Sent: tirsdag 31. mars 2020 15:42
> Cc: Markus Neteler <neteler at osgeo.org><mailto:neteler at osgeo.org>; GRASS user list <grass-user at lists.osgeo.org><mailto:grass-user at lists.osgeo.org>
> Hi Stefan,
> thank you very much for the effort and the patience in answering!
> I'll definitely give this a try. I already have so many issues on my computer, one more doesn't matter;)
> thanks again and best regards,
> Robin
> Citando Stefan Blumentrath <Stefan.Blumentrath at nina.no><mailto:Stefan.Blumentrath at nina.no>:
>> Hi Robin,
>> You could try setting the GRASS_PYTHON environment variable to your
>> Python installation with fmask.
>> import os
>> os.environ['GRASS_PYTHON'] = '/YOUR/PYTHON/PATH'
>> As Markus indicates that can cause other issues.
>> You may also have a look at https://github.com/zarch/grass-session
>> for inspiration.
>> Hope that gives you at least a lead...
>> Cheers
>> Stefan
>> From: grass-user <grass-user-bounces at lists.osgeo.org><mailto:grass-user-bounces at lists.osgeo.org> On Behalf Of
>> Robin Kohrs
>> Sent: tirsdag 31. mars 2020 09:25
>> To: Markus Neteler <neteler at osgeo.org><mailto:neteler at osgeo.org>
>> Cc: GRASS user list <grass-user at lists.osgeo.org><mailto:grass-user at lists.osgeo.org>
>> /usr/bin/python3
>> Hi Markus,
>> thank you very much for your answer and the help!
>> Do you have any idea what I could do to make the fmask-package
>> "locatable" for the python-interpreter that grass is using?
>> I tried the following options, but I guess I just don't know
>> sufficiently about how python and grass really work together:
>> My python-script looks more or less like this:
>> #!/usr/bin/env python3
>> import sys
>> print("SYS PATH")
>> print(sys.path)
>> print("")
>> print("SYS EXECUTABLE")
>> print(sys.executable)
>> import grass.script as grass
>> from rios import fileinfo # that's where it fails from fmask import
>> fmask
>> That's why I tried until now:
>> - I created an environment with conda and installed python-fmask via
>> "conda install -c conda-forge python-fmask". The function
>> "fmask_sentinel2Stacked.py" lies in
>> "/home/robin/miniconda3/bin/fmask_sentinel2Stacked.py".
>> - When I open an interactive python-shell and import fmask and rios
>> and the type: "fmask.__file__" it gives me
>> "/home/robin/miniconda3/envs/fmask/lib/python3.7/site-packages/fmask/__init__.py"
>> - I then added
>> "/home/robin/miniconda3/envs/fmask/lib/python3.7/site-packages/" to
>> the variable PYTHONPATH in my .bashrc
>> - When I now start the interpreter that grass uses from the command
>> line by typing "/usr/bin/pyton3" I can import fmask and rios
>> - However when I run the script with grass it always says that there
>> is no package names rios. Moreover the path I added to PYTHONPATH is
>> not printed when it executes "sys.path" in my grass script
>> I'm sorry for this little confusing question. But in case someone
>> has any idea how I could make grass find fmask, would be super highly
>> appreciated:)
>> thanks a lot in advance! Cheers
>> Robin
>> Citando Markus Neteler <neteler at osgeo.org><mailto:neteler at osgeo.org>:
>>> Hi Robin,
>>> On Sat, Mar 21, 2020 at 6:15 PM Robin Kohrs <robin.kohrs at uni-jena.de><mailto:robin.kohrs at uni-jena.de> wrote:
>>>> Hi everyone:)
>>>> I'm really sorry for this naive question. I'm kind of starting with
>>>> GRASS and I just can't find a solution...
>>>> The issue is, that I would like to try to write a little GRASS Add-on
>>>> and use the python-fmask package. While this package is only
>>>> downloadable via conda it always installs into
>>>> `/home/user/miniconda3/bin/python3`. Even when I did `conda
>>>> deactivate` prior to this.
>>> I guess that mixing conda packages and "regular" ones is causing troubles.
>>>> When I then have the import statement `import fask` in the
>>>> grass-script it always throws an error, saying that fmask is not
>>>> installed. When I print the `sys.executable` in the grass-script it
>>>> tells me that the interpreter is in `usr/bin/python3`. So I thought
>>>> that I'd install the fmask-package in a way that this interpreter can
>>>> find it while executing the script. But I just don't know how. I can
>>>> add the fmask-path to sys.path, but I don't think this is the
>>>> solution. Maybe someone has a pointer what I'm not getting.
>>> There is also the environment variable PYTHONPATH which could be set
>>> in the session.
>>> But again, mixing might cause problems.
>>> Now I wanted to check
>>> http://pythonfmask.org/en/latest/#downloads
>>> but the server is down...
>>>> Hope everyone is good these days:)!
>>> Good luck everyone,
>>> Markus
>> grass-user mailing list
>> grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200408/0f20031f/attachment-0001.html>
