[GRASS-user] Question with algorithm 'r.mapcalc.simple' from QGIS GUI
Vaclav Petras wenzeslaus at gmail.com
Thu Apr 9 18:46:56 PDT 2020
On Sun, Apr 5, 2020 at 2:51 PM Valter Albino <valteralbino at gmail.com> wrote:
> I can see it [https://grass.osgeo.org/grass78/manuals/r.mapcalc.html].
> Altought for the example that was presented the syntax doesn't work, it's
> a fine solution, thanks Pedro!
Hi, I'm getting back to this to ask about the example with syntax which
does not work. What example are you talking about?
> Pedro Venâncio <pedrongvenancio at gmail.com> escreveu no dia domingo,
> 5/04/2020 à(s) 19:31:
>> Valter logical and in GRASS is &&.
>> Best regards,
>> Pedro
>> A domingo, 5/04/2020, 19:11, Valter Albino <valteralbino at gmail.com>
>> escreveu:
>>> OK, it doesn't support this type of function: "Undefined function
>>> 'logical_and'"
>>> Hey, but GDAL raster calculator in QGIS GUI does!
>>> Cumprimentos,
>>> *Valter Albino -* Geógrafo Físico, M.Sc.
>>> Modelação H&H / Riscos ambientais / OT&U
>>> www.valteralbino.wixsite.com/hydrodynamics
>>> Valter Albino <valteralbino at gmail.com> escreveu no dia domingo,
>>> 5/04/2020 à(s) 18:50:
>>>> Hi
>>>> Searching for a solution do compute a simple "if else" expression with
>>>> 'r.mapcalc.simple' from QGIS GUI.
>>>> Don't understand the following message. Someone have any clue?
>>>> QGIS version: 3.12.1-București
>>>> QGIS code revision: 121cc00ff0
>>>> Qt version: 5.11.2
>>>> GDAL version: 3.0.4
>>>> GEOS version: 3.8.1-CAPI-1.13.3
>>>> PROJ version: Rel. 6.3.1, February 10th, 2020
>>>> Processing algorithm…
>>>> Algorithm 'r.mapcalc.simple' starting…
>>>> Input parameters:
>>>> { 'GRASS_RASTER_FORMAT_META' : '', 'GRASS_RASTER_FORMAT_OPT' : '',
>>>> 'GRASS_REGION_CELLSIZE_PARAMETER' : 5, 'GRASS_REGION_PARAMETER' :
>>>> '-59062.1289,-38278.9651,-78283.947,-59308.1937 [EPSG:3763]', 'a' :
>>>> 'H:/recLUvalue.tif', 'b' : 'H:/recSoilNu.tif', 'c' : None, 'd' : None, 'e'
>>>> : None, 'expression' : '99*(A==1) + 91*logical_and(A==2, B==1) +
>>>> 94*logical_and(A==2, B==2) + 96*logical_and(A==2, B==3) +
>>>> 97*logical_and(A==2, B==4) + 93*logical_and(A==3, B==1) +
>>>> 95*logical_and(A==3, B==2) + 97*logical_and(A==3, B==3) +
>>>> 97*logical_and(A==3, B==4) + 91*logical_and(A==4, B==1) +
>>>> 94*logical_and(A==4, B==2) + 96*logical_and(A==4, B==3) +
>>>> 97*logical_and(A==4, B==4) + 78*logical_and(A==5, B==1) +
>>>> 86*logical_and(A==5, B==2) + 91*logical_and(A==5, B==3) +
>>>> 92*logical_and(A==5, B==4) + 100*(A==1) + 79*logical_and(A==8, B==1) +
>>>> 87*logical_and(A==8, B==2) + 91*logical_and(A==8, B==3) +
>>>> 93*logical_and(A==8, B==4) + 78*logical_and(A==9, B==1) +
>>>> 86*logical_and(A==9, B==1) + 91*logical_and(A==9, B==2) +
>>>> 93*logical_and(A==9, B==3) + 72*logical_and(A==11, B==1) +
>>>> 84*logical_and(A==11, B==2) + 90*logical_and(A==11, B==3) +
>>>> 92*logical_and(A==11, B==4) + 45*logical_and(A==12, B==1) +
>>>> 71*logical_and(A==12, B==2) + 79*logical_and(A==12, B==3) +
>>>> 84*logical_and(A==12, B==4) + 50*logical_and(A==13, B==1) +
>>>> 76*logical_and(A==13, B==2) + 85*logical_and(A==13, B==3) +
>>>> 89*logical_and(A==13, B==4) + 75*logical_and(A==14, B==1) +
>>>> 87*logical_and(A==14, B==2) + 93*logical_and(A==14, B==3) +
>>>> 96*logical_and(A==14, B==4)', 'f' : None, 'output' : 'TEMPORARY_OUTPUT' }
>>>> g.proj -c proj4="+proj=tmerc +lat_0=39.6682583333333
>>>> +lon_0=-8.13310833333333 +k=1 +x_0=0 +y_0=0 +ellps=GRS80
>>>> +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
>>>> r.in.gdal input="H:\recLUvalue.tif" band=1 output="rast_5e8a18a12ad402"
>>>> --overwrite -o
>>>> r.in.gdal input="H:\recSoilNu.tif" band=1 output="rast_5e8a18a12ad403"
>>>> --overwrite -o
>>>> g.region n=-59308.1937 s=-78283.947 e=-38278.9651 w=-59062.1289 res=5.0
>>>> r.mapcalc.simple a=rast_5e8a18a12ad402 b=rast_5e8a18a12ad403
>>>> expression="99*(A==1) + 91*logical_and(A==2, B==1) + 94*logical_and(A==2,
>>>> B==2) + 96*logical_and(A==2, B==3) + 97*logical_and(A==2, B==4) +
>>>> 93*logical_and(A==3, B==1) + 95*logical_and(A==3, B==2) +
>>>> 97*logical_and(A==3, B==3) + 97*logical_and(A==3, B==4) +
>>>> 91*logical_and(A==4, B==1) + 94*logical_and(A==4, B==2) +
>>>> 96*logical_and(A==4, B==3) + 97*logical_and(A==4, B==4) +
>>>> 78*logical_and(A==5, B==1) + 86*logical_and(A==5, B==2) +
>>>> 91*logical_and(A==5, B==3) + 92*logical_and(A==5, B==4) + 100*(A==1) +
>>>> 79*logical_and(A==8, B==1) + 87*logical_and(A==8, B==2) +
>>>> 91*logical_and(A==8, B==3) + 93*logical_and(A==8, B==4) +
>>>> 78*logical_and(A==9, B==1) + 86*logical_and(A==9, B==1) +
>>>> 91*logical_and(A==9, B==2) + 93*logical_and(A==9, B==3) +
>>>> 72*logical_and(A==11, B==1) + 84*logical_and(A==11, B==2) +
>>>> 90*logical_and(A==11, B==3) + 92*logical_and(A==11, B==4) +
>>>> 45*logical_and(A==12, B==1) + 71*logical_and(A==12, B==2) +
>>>> 79*logical_and(A==12, B==3) + 84*logical_and(A==12, B==4) +
>>>> 50*logical_and(A==13, B==1) + 76*logical_and(A==13, B==2) +
>>>> 85*logical_and(A==13, B==3) + 89*logical_and(A==13, B==4) +
>>>> 75*logical_and(A==14, B==1) + 87*logical_and(A==14, B==2) +
>>>> 93*logical_and(A==14, B==3) + 96*logical_and(A==14, B==4)"
>>>> output=outputb7f2c5ec865148f6a92bddf859fdf839 --overwrite
>>>> g.region raster=outputb7f2c5ec865148f6a92bddf859fdf839
>>>> r.out.gdal -t -m input="outputb7f2c5ec865148f6a92bddf859fdf839"
>>>> output="C:\Users\Particular\AppData\Local\Temp\processing_GWGaYw\1c703db4b0d14b2a88c0e57e10cf8d6e\output.tif"
>>>> format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
>>>> Starting GRASS GIS...
>>>> WARNING: Concurrent mapset locking is not supported on Windows
>>>> Cleaning up temporary files...
>>>> Executing
>>>> <C:\Users\Particular\AppData\Local\Temp\processing_GWGaYw\grassdata\grass_batch_job.cmd>
>>>> C:\Users\Particular\Documents>chcp 1252 1>NUL
>>>> C:\Users\Particular\Documents>g.proj -c proj4="+proj=tmerc
>>>> +lat_0=39.6682583333333 +lon_0=-8.13310833333333 +k=1 +x_0=0 +y_0=0
>>>> +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
>>>> Default region was updated to the new projection, but if you have
>>>> multiple mapsets `g.region -d` should be run in each to update the region
>>>> from the default
>>>> Projection information updated
>>>> C:\Users\Particular\Documents>r.in.gdal input="H:\recLUvalue.tif"
>>>> band=1 output="rast_5e8a18a12ad402" --overwrite -o
>>>> Over-riding projection check
>>>> Importing raster map <rast_5e8a18a12ad402>...
>>>> 0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45..48..51..54..57..60..63..66..69..72..75..78..81..84..87..90..93..96..99..100
>>>> C:\Users\Particular\Documents>r.in.gdal input="H:\recSoilNu.tif" band=1
>>>> output="rast_5e8a18a12ad403" --overwrite -o
>>>> Importing raster map <rast_5e8a18a12ad403>...
>>>> C:\Users\Particular\Documents>g.region n=-59308.1937 s=-78283.947
>>>> C:\Users\Particular\Documents>r.mapcalc.simple a=rast_5e8a18a12ad402
>>>> b=rast_5e8a18a12ad403 expression="99*(A==1) + 91*logical_and(A==2, B==1) +
>>>> 96*logical_and(A==14, B==4)" output=outputb7f2c5ec865148f6a92bddf859fdf839
>>>> --overwrite
>>>> Undefined function 'logical_and'
>>>> Parse error
>>>> ERROR: parse error
>>>> ERROR: An error occurred while running r.mapcalc with expression:
>>>> outputb7f2c5ec865148f6a92bddf859fdf839 = 99*(rast_5e8a18a12ad402==1) +
>>>> 91*logical_and(rast_5e8a18a12ad402==2, rast_5e8a18a12ad403==1) +
>>>> 94*logical_and(rast_5e8a18a12ad402==2, rast_5e8a18a12ad403==2) +
>>>> 96*logical_and(rast_5e8a18a12ad402==2, rast_5e8a18a12ad403==3) +
>>>> 97*logical_and(rast_5e8a18a12ad402==2, rast_5e8a18a12ad403==4) +
>>>> 93*logical_and(rast_5e8a18a12ad402==3, rast_5e8a18a12ad403==1) +
>>>> 95*logical_and(rast_5e8a18a12ad402==3, rast_5e8a18a12ad403==2) +
>>>> 97*logical_and(rast_5e8a18a12ad402==3, rast_5e8a18a12ad403==3) +
>>>> 97*logical_and(rast_5e8a18a12ad402==3, rast_5e8a18a12ad403==4) +
>>>> 91*logical_and(rast_5e8a18a12ad402==4, rast_5e8a18a12ad403==1) +
>>>> 94*logical_and(rast_5e8a18a12ad402==4, rast_5e8a18a12ad403==2) +
>>>> 96*logical_and(rast_5e8a18a12ad402==4, rast_5e8a18a12ad403==3) +
>>>> 97*logical_and(rast_5e8a18a12ad402==4, rast_5e8a18a12ad403==4) +
>>>> 78*logical_and(rast_5e8a18a12ad402==5, rast_5e8a18a12ad403==1) +
>>>> 86*logical_and(rast_5e8a18a12ad402==5, rast_5e8a18a12ad403==2) +
>>>> 91*logical_and(rast_5e8a18a12ad402==5, rast_5e8a18a12ad403==3) +
>>>> 92*logical_and(rast_5e8a18a12ad402==5, rast_5e8a18a12ad403==4) +
>>>> 100*(rast_5e8a18a12ad402==1) + 79*logical_and(rast_5e8a18a12ad402==8,
>>>> rast_5e8a18a12ad403==1) + 87*logical_and(rast_5e8a18a12ad402==8,
>>>> rast_5e8a18a12ad403==2) + 91*logical_and(rast_5e8a18a12ad402==8,
>>>> rast_5e8a18a12ad403==3) + 93*logical_and(rast_5e8a18a12ad402==8,
>>>> rast_5e8a18a12ad403==4) + 78*logical_and(rast_5e8a18a12ad402==9,
>>>> rast_5e8a18a12ad403==1) + 86*logical_and(rast_5e8a18a12ad402==9,
>>>> rast_5e8a18a12ad403==1) + 91*logical_and(rast_5e8a18a12ad402==9,
>>>> rast_5e8a18a12ad403==2) + 93*logical_and(rast_5e8a18a12ad402==9,
>>>> rast_5e8a18a12ad403==3) + 72*logical_and(rast_5e8a18a12ad402==11,
>>>> rast_5e8a18a12ad403==1) + 84*logical_and(rast_5e8a18a12ad402==11,
>>>> rast_5e8a18a12ad403==2) + 90*logical_and(rast_5e8a18a12ad402==11,
>>>> rast_5e8a18a12ad403==3) + 92*logical_and(rast_5e8a18a12ad402==11,
>>>> rast_5e8a18a12ad403==4) + 45*logical_and(rast_5e8a18a12ad402==12,
>>>> rast_5e8a18a12ad403==1) + 71*logical_and(rast_5e8a18a12ad402==12,
>>>> rast_5e8a18a12ad403==2) + 79*logical_and(rast_5e8a18a12ad402==12,
>>>> rast_5e8a18a12ad403==3) + 84*logical_and(rast_5e8a18a12ad402==12,
>>>> rast_5e8a18a12ad403==4) + 50*logical_and(rast_5e8a18a12ad402==13,
>>>> rast_5e8a18a12ad403==1) + 76*logical_and(rast_5e8a18a12ad402==13,
>>>> rast_5e8a18a12ad403==2) + 85*logical_and(rast_5e8a18a12ad402==13,
>>>> rast_5e8a18a12ad403==3) + 89*logical_and(rast_5e8a18a12ad402==13,
>>>> rast_5e8a18a12ad403==4) + 75*logical_and(rast_5e8a18a12ad402==14,
>>>> rast_5e8a18a12ad403==1) + 87*logical_and(rast_5e8a18a12ad402==14,
>>>> rast_5e8a18a12ad403==2) + 93*logical_and(rast_5e8a18a12ad402==14,
>>>> rast_5e8a18a12ad403==3) + 96*logical_and(rast_5e8a18a12ad402==14,
>>>> Execution of
>>>> finished.
>>>> Press any key to continue . . .
>>>> Executing
>>>> ERROR: Raster map <outputb7f2c5ec865148f6a92bddf859fdf839> not found
>>>> C:\Users\Particular\Documents>r.out.gdal -t -m
>>>> ERROR: Raster map or group <outputb7f2c5ec865148f6a92bddf859fdf839> not
>>>> found
>>>> C:\Users\Particular\Documents>exit
>>>> Execution of
>>>> finished.
>>>> Execution completed in 2.38 seconds
>>>> Results:
>>>> {'output': <QgsProcessingOutputLayerDefinition
>>>> {'sink':TEMPORARY_OUTPUT, 'createOptions': {'fileEncoding': 'System'}}>}
>>>> Loading resulting layers
>>>> The following layers were not correctly
>>>> generated.<ul><li>C:/Users/Particular/AppData/Local/Temp/processing_GWGaYw/1c703db4b0d14b2a88c0e57e10cf8d6e/output.tif</li></ul>You
>>>> can check the 'Log Messages Panel' in QGIS main window to find more
>>>> information about the execution of the algorithm.
>>>> This is the GRASS log message:
>>>> 2020-04-05T18:42:57     INFO    processInputs end. Commands: ['g.proj
>>>> -c proj4="+proj=tmerc +lat_0=39.6682583333333 +lon_0=-8.13310833333333 +k=1
>>>> +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"',
>>>> 'r.in.gdal input="H:\\recLUvalue.tif" band=1 output="rast_5e8a18a12ad402"
>>>> --overwrite -o', 'r.in.gdal input="H:\\recSoilNu.tif" band=1
>>>> output="rast_5e8a18a12ad403" --overwrite -o', 'g.region n=-59308.1937
>>>> s=-78283.947 e=-38278.9651 w=-59062.1289 res=5.0']
>>>> 2020-04-05T18:42:57     INFO    processCommands end. Commands:
>>>> ['g.proj -c proj4="+proj=tmerc +lat_0=39.6682583333333
>>>> +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"', 'r.in.gdal
>>>> input="H:\\recLUvalue.tif" band=1 output="rast_5e8a18a12ad402" --overwrite
>>>> s=-78283.947 e=-38278.9651 w=-59062.1289 res=5.0', 'r.mapcalc.simple
>>>> a=rast_5e8a18a12ad402 b=rast_5e8a18a12ad403 expression="99*(A==1) +
>>>> 91*logical_and(A==2, B==1) + 94*logical_and(A==2, B==2) +
>>>> output=outputb7f2c5ec865148f6a92bddf859fdf839 --overwrite']
>>>> Thanks in advance
>>>> Cumprimentos,
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200409/6374ad39/attachment-0001.html>
